What fuel for my combo ?
Tennessee Bullitt
jc10000rpm
56Tbird
nuclearcobra
What fuel for my combo ? Empty What fuel for my combo ?
Post  nuclearcobra October 14th 2011, 10:01 am
Im wondering if i can get away with a 110/93 half and half mix vs. straight 110 ? its a 472'' with scj diamond flat tops and scj heads, the piston was about .006 in the hole, the cam is a solid flat tappit 260-268 @.050 637-648 lift. Randy M said before that 12to1 is to low for straight 110 but to high for 93 so it got me thinking maybe i can mix it.
nuclearcobra
nuclearcobra
What fuel for my combo ? Empty Re: What fuel for my combo ?
Post  rmcomprandy October 14th 2011, 10:34 am
nuclearcobra wrote:Im wondering if i can get away with a 110/93 half and half mix vs. straight 110 ? its a 472'' with scj diamond flat tops and scj heads, the piston was about .006 in the hole, the cam is a solid flat tappit 260-268 @.050 637-648 lift. Randy M said before that 12to1 is to low for straight 110 but to high for 93 so it got me thinking maybe i can mix it.
M+R divided by 2 ... 100 to 104 octane gasoline.
Post  nuclearcobra October 14th 2011, 11:34 am
Thanks Randy , i had a chart years ago that gave all the diffrent octanes when mixing fuels but have never been able to find it Rolling Eyes figures one of those things i put away so i would never misplace it again Mad Damn i hate good hiding spots they work everytime Embarassed
Last edited by nuclearcobra on October 14th 2011, 12:22 pm; edited 1 time in total
nuclearcobra
nuclearcobra
Post  nuclearcobra October 14th 2011, 12:21 pm
Found it on wallace racing calculaters 50/50 mix of 110 and 93 =101.5 octane
nuclearcobra
nuclearcobra
Post  nuclearcobra October 14th 2011, 12:24 pm
So 100 to 104 is what i should use for my combo ?
nuclearcobra
nuclearcobra
Post  rmcomprandy October 14th 2011, 3:47 pm
nuclearcobra wrote:Found it on wallace racing calculaters 50/50 mix of 110 and 93 =101.5 octane
That is SOooo wrong ... it is presuming both fuels are leaded fuels of a certain amount.
It could be anywhere from 98 to 105 depending upon how much tetraethelead is within each one's chemical make-up or whether or not lead is present at all.
Appropriate Gasoline:
Leaded?
VP "Motorsport 103"
VP C11
Turbo Blue
Leaded, Oygenated ?
VP "Motorsport 109E" (with Ethanol and really heavy specific gravity)
VP MRX-01
VP VPR
VP U4.4
Unleaded with Ethanol Oxygenate ? (street legal and catalytic converter friendly)
VP 100 (aka Street Blaze 100)
Unleaded ?
VP C10
Sunoco 100
Rocket Racing unleaded (Union 76 unleaded)
Post  56Tbird October 14th 2011, 7:38 pm
Put it on methanol and be done with it!!
56Tbird
56Tbird
Post  jc10000rpm October 14th 2011, 8:14 pm
could be a good candidate for e-85 if available in your area,
jc10000rpm
Post  Tennessee Bullitt October 14th 2011, 8:46 pm
Randy, My A-headded deal gonna be around 12:1 how would C12 work. I am gonna spray nitrous and was thinking running a seperate cell with c16 for a big shot. Does the cam play a factor for fuel selection? Didn't mean to hijack the thread.
Tennessee Bullitt
Tennessee Bullitt
Post  cool40 October 14th 2011, 9:31 pm
56Tbird wrote:Put it on methanol and be done with it!!
x2 Razz
Post  rmcomprandy October 14th 2011, 9:55 pm
Tennessee Bullitt wrote:Randy, My A-headded deal gonna be around 12:1 how would C12 work. I am gonna spray nitrous and was thinking running a seperate cell with c16 for a big shot. Does the cam play a factor for fuel selection? Didn't mean to hijack the thread.
C12 is probably one of the most used leaded racing fuels ever, LOL.
It probably has a lot to do with cost and being SPEC fuel for a lot of organizations..
Personally, I would look into using VP113 oxygenated fuel which weighs almost the same and it will make more power at your 12/1 compression ratio. You won't need to use something different for nitrous.
Post  Tennessee Bullitt October 14th 2011, 10:12 pm
I am looking up to a 400 shot. Does that change things?
Tennessee Bullitt
Tennessee Bullitt
Post  Lem Evans October 14th 2011, 10:16 pm
with what comp. ratio and with how much timing retard when the spray is on?
Post  richter69 October 15th 2011, 2:14 am
x2 Razz
x3
Post  dfree383 October 15th 2011, 2:16 am
Alky's for Drinkin', Gas is for Racin'........... pirat
Post  rmcomprandy October 15th 2011, 1:13 pm
The HP size of the nitrous system doesn't make any difference as long as the MIXTURE and ignition timing is correct.
Post  Tennessee Bullitt October 15th 2011, 7:06 pm
Around 12:1 and what ever timing is needed to be taken out. I discussed with Bob that I am goning to run the MSD power grid setup for ignition and the timing system. I thought about doing around 13:1 but I think 12:1 will give me more of a window to be safe.
Tennessee Bullitt
Tennessee Bullitt
Post  nuclearcobra October 18th 2011, 2:35 pm
You guys are wrong it runs like crap on alky, plus the two gallons of vodka i dumped in it was expensive Shocked
nuclearcobra
nuclearcobra
Post  Tennessee Bullitt October 18th 2011, 3:45 pm
I have to agree with you there.^^^^^^^^^^^^^^^^^^
Tennessee Bullitt
Tennessee Bullitt
