Camshaft material
Camshaft material
Has anybody used a compcams austempred core mech roller cam
darren- Posts : 64
Re: Camshaft material
darren wrote:Has anybody used a compcams austempred core mech roller cam
Lots of times. However, they have used two different ones of different graded steels.
Make sure you use the correct distributor gear no matter what shaft you get...
jasonf- BBF CONTRIBUTOR
Thanks Guy's, I think I will stick with steel billet .
darren- Posts : 64
darren wrote:Thanks Guy's, I think I will stick with steel billet .
Full billets are 9310 and UGL billets are usually 8620.
5150 is a common roller core material however, it doesn't stand up well to aggressive grinds; hydraulic rollers are usually OK as well as Solid street rollers.
8660 is a tempered steel Semi-Ground-Lobes which is a super blank.
» Isky Red Zone and Crower Bushed Lifters. ( Bushing Material)??
» camshaft
» Four bolt main caps material
» Needing advise on a 598ci street friendly drag radial Foxbody on pump gas
» Cam gear material type...Iron or steel?
» camshaft
