Cam gear material type...Iron or steel?
8liter
What dictates the choice? Is it the thrust surface metals or the cam type? I see where they offer steel and iron cam and crank gears. I've got a steel crank and a solid roller cam, but I'm using the factory retainer plate. Was looking at a Cloyes.
Thanks, Casey
Thanks, Casey
8liter- Posts : 202
Re: Cam gear material type...Iron or steel?
W/roller, go w/billet steel and double roller set. Call Lem,he's the cheapest.
A steel cam gear is stronger than a ductile iron gear. The thrust plate used has to be a match to the gear.8liter wrote:What dictates the choice? Is it the thrust surface metals or the cam type? I see where they offer steel and iron cam and crank gears. I've got a steel crank and a solid roller cam, but I'm using the factory retainer plate. Was looking at a Clouds.
Thanks, Casey
[/quote]A steel cam gear is stronger than a ductile iron gear. The thrust plate used has to be a match to the gear.[/quote]
That's what I was thinking. Who makes a steel retaining plate? What about thrust bearings? I see they make them for the cam side as well as the gear side of the retainer.
8liter- Posts : 202
What you need , i.m.o. , is a timing set with a steel top gear & a bronze retainer plate.
Lem Evans wrote:What you need , i.m.o. , is a timing set with a steel top gear & a bronze retainer plate.
Redouble post .
Sounds legit.Lem Evans wrote:Lem Evans wrote:What you need , i.m.o. , is a timing set with a steel top gear & a bronze retainer plate.
Redouble post .
UpdateLem Evans wrote:Sounds legit.Lem Evans wrote:Lem Evans wrote:What you need , i.m.o. , is a timing set with a steel top gear & a bronze retainer plate.
Redouble post .
AmenLem Evans wrote:UpdateLem Evans wrote:Sounds legit.Lem Evans wrote:Lem Evans wrote:What you need , i.m.o. , is a timing set with a steel top gear & a bronze retainer plate.
Redouble post .
start it and do a burnout.......Lem Evans wrote:AmenLem Evans wrote:UpdateLem Evans wrote:Sounds legit.Lem Evans wrote:Lem Evans wrote:What you need , i.m.o. , is a timing set with a steel top gear & a bronze retainer plate.
Redouble post .
Kitten killing bastard.
maverick- BBF CONTRIBUTOR
Ok. Thanks guys..now, please burn frayed end of the thread.....
8liter- Posts : 202
Nice pic's lem,good info.Lem Evans wrote:What you need , i.m.o. , is a timing set with a steel top gear & a bronze retainer plate.
Oh yea,I like puppy's8)
bbf-falcon wrote:Nice pic's lem,good info.Lem Evans wrote:What you need , i.m.o. , is a timing set with a steel top gear & a bronze retainer plate.
Bastard killing kittens.maverick wrote:Kitten killing bastard.
» WANTED: steel distributor gear for 460
» Distributor gear for steel roller cam
» Steel Dizzy Gear & IDT Block?
» Mercon VS Type F....my 95 F-150 manual says to use Mercon...would type F hurt my 4R70W trans?
» Factory production Chrysler iron hemi head vs iron cobra jet
