Distributor gear for steel roller cam
Distributor gear for steel roller cam Empty Distributor gear for steel roller cam
Post  JBR-3 December 14th 2017, 3:59 am
Last edited by JBR-3 on September 20th 2020, 1:40 pm; edited 1 time in total (Reason for editing : .)
JBR-3
Distributor gear for steel roller cam Empty Re: Distributor gear for steel roller cam
Post  BBFTorino December 14th 2017, 4:34 am
Yes. Regardless of what kind of oil pump, the distributor gear must be a Bronze (or Nylon) gear. You cannot have two hard gear together, one must be a softer material.
Post  rmcomprandy December 14th 2017, 10:23 am
JBR-3 wrote:I plan on using an external belt-driven oil pump.
Given this, does it make much difference what kind of distributor gear I use with a steel cam ?
A bronze or composite distributor gear can be used on all ... some grade steel cams can use a steel gear; (not iron).
Post  JBR-3 December 14th 2017, 2:25 pm
JBR-3
Post  JBR-3 December 14th 2017, 2:38 pm
Last edited by JBR-3 on September 20th 2020, 1:41 pm; edited 1 time in total (Reason for editing : .)
JBR-3
Post  bosshoss December 15th 2017, 2:27 am
different type of gear mesh... hypoid gears versus spiral gears.. big difference
bosshoss
bosshoss
Post  JBR-3 December 15th 2017, 1:02 pm
Last edited by JBR-3 on September 20th 2020, 1:42 pm; edited 1 time in total (Reason for editing : .)
JBR-3
Post  Carl December 15th 2017, 4:57 pm
Might consider the Lunati gear also (probably made by Crane).
http://www.jegs.com/i/Lunati/638/89100/10002/-1
http://cranecams.com.au/pdfs/pp1110a.pdf
Carl
