Engine mounts
Engine mounts Empty Engine mounts
Post  56effie September 15th 2009, 8:19 am
Need some help with engine mounts I have a 56 f100 that is running a 390FEbigblock and iwant to run a 429/460 based strocker will a DOVE A block bolt in where the FE was as in the mounting points on the chassis cross member? Will i need to change this or just get some 429/460 rubber engine mounts? Any help/advise would be great!
56effie
Engine mounts Empty Re: Engine mounts
Post  res0rli9 September 15th 2009, 1:58 pm
get 66 farlane 390GT mounts and switch sides put the lft on rt and rt on lft, but only 2 bolt holes will line up on the block, did this on 76 F150 with 466 and its worked for 15yrs. its a street truck.
