Engine Mounts
jeffgfg
wickettoby1
Slowride
Engine Mounts Empty Engine Mounts
Post  wickettoby1 July 1st 2018, 6:34 pm
I need to make some custom engine mounts for my 545 project. Does anyone care to share their custom engine mount pictures or ideas. If their rubber, poly, or solid I don’t discriminate.
Justin
wickettoby1
Engine Mounts Empty Re: Engine Mounts
Post  Mike R July 1st 2018, 8:50 pm
Motor plates, they allow you to place it anywhere and give lots of header room
Post  wickettoby1 July 1st 2018, 8:59 pm
Thanks for the words of wisdom Mike but it doesn't really answer the question that I asked.
wickettoby1
Post  Slowride July 1st 2018, 9:47 pm
Can't help with drawings and dimensions, but I used a prefabbed kit from Tinman and modified it to put the 545 in my '32.
http://www.tinmanfabrication.com/index.cfm/page/ptype=product/product_id=90/prd90.htm
Engine Mounts Mnt3
A little different angle
Engine Mounts Mnt4
Slowride
Post  wickettoby1 July 1st 2018, 10:04 pm
Thanks for the info Tinman
wickettoby1
Post  jeffgfg July 2nd 2018, 5:36 am
Speedway motors..has mounts for 99.00 they work great.
jeffgfg
Post  wickettoby1 July 2nd 2018, 6:39 am
Thanks for the heads up Jeff
wickettoby1
Post  Doug Rahn July 2nd 2018, 6:52 am
All I can offer are the dimensions of the bolt pattern in the block sides.
Engine Mounts Motor-mount-bolt-pattern
Post  Slowride July 3rd 2018, 6:42 pm
I looked at a LOT of mounts and went with the Tinman mounts for a couple reasons. I wanted the bushings (pivot points) as close to the frame rail as I could for clearance and reduce the rotation from torque. I wasn't fond of the Speedway bracket off the rail as it didn't look strong enough. Probably just me and a case of overkill, but what I would have saved with the Speedway mount I would have more than spent modifying brackets and headers.
Slowride
Post  wickettoby1 July 3rd 2018, 7:00 pm
I like the design of the Tinman mounts they just won't work for my particular application.
wickettoby1
Post  jbozzelle July 4th 2018, 7:09 am
wickettoby1 wrote:I like the design of the Tinman mounts they just won't work for my particular application.
What is your particular application? Post up details and maybe someone can point you in the right direction.
Post  wickettoby1 July 4th 2018, 7:17 am
It's a 1964 Galaxie with a TKO behind it and before anyone says "just buy the Crites mounts" I already have the Crites mounts and dont really care for them.
Justin
wickettoby1
Post  BBFTorino July 4th 2018, 5:19 pm
There are a lot of Crites products that are junk and don't fit very well, or at all.
Post  wickettoby1 July 4th 2018, 6:05 pm
When I bought my Crites mounts i waited several weeks to get them even though every time I called they said "their shipping today". Then when I did finally receive them they sent 2 right side mounts. I called and told them that id be there in the morning (after a 3 hr drive) and that id like to have a conversation with the owner. When i arrived the owner wasn't there and when I gave them my extra right side mount to exchange for a left they came back with another right side mount. Apparently the left and right mount bins were both filled with right side mounts. I had to wait while they made me a left side mount. After that i said id never buy another product from them. I'll get off of my soapbox now Wink
Justin
wickettoby1
Post  Doug Rahn July 5th 2018, 5:27 am
What style engine mount are you looking for?
Post  jasonf July 5th 2018, 7:10 am
I have a 64 Galaxie as well so whatever you come up with please share it.
Post  wickettoby1 July 5th 2018, 7:43 am
I'll probably end up going with a solid mount because the 545 that I'm putting together is gonna make quite a bit of hp and torque for a street car.
The '64 Galaxie has a perch on each side that sits on the crossmember under the engine. The perch has a hole in it for a threaded stud to go through then a nut and washer go on the bottom side.
I'll take a pic and post it later today.
wickettoby1
Post  Doug Rahn July 5th 2018, 8:20 am
wickettoby1 wrote:I'll probably end up going with a solid mount because the 545 that I'm putting together is gonna make quite a bit of hp and torque for a street car.
Okay. Knowing that the factory mounts bolt to the cross-member, that was a similar deal on a 460 I setup for one of my nephews who had a '70's Ford Pickup. On that, I used the mount that Rod & Custom Motorsports has that they offer with their MII suspension Kits. It's available separately with many engines mounts, including the 460. It's a stanchion type, but instead of welding it directly to the cross- member, I welded it to some plate and boted that to the cross-member so it would also be removable. Worked really good and took a beating at the track. I found this similar setup on the web and as you can see they welded it to the cross-member.
Engine Mounts Dscn5567_zps036f7df8-jpg
