3040 hp A460 Dyno
+22
2POWERADDERS
Frank Kramer
dtimmer
Kevin323K
mtacqua
bigjohn2007
Barney
Finmach
badmach
Oakley Motorsports
'65 T-BOLT
jrc performance
hpwdboss1
Injected65
26 posters
Page 2 of 2 Previous  1, 2
3040 hp A460 Dyno - Page 2 Empty Re: 3040 hp A460 Dyno
Post  Finmach November 23rd 2011, 8:38 am
badmach wrote:Yes sir split leafs and caltrac bars
Wow! That Mach 1 is unbeliavable! Leafsprings gives me a belief for my current setup, I've got similar '72 Mach with calvert and M9 with 35splines axles. What about your front suspension, you have had to remove the shocktowers somehow? Any pictures available from the front suspension or enginebay somewhere? I have two different sets of BBC exhaustflange turboheaders just hanging on the wall - I got them dirt cheap. Decided to get them since they could be used with A460 heads.
Finmach
Finmach
Post  Barney November 23rd 2011, 7:49 pm
thats wicked impressive.
Barney
Barney
Post  bigjohn2007 February 11th 2012, 8:27 pm
i feel sorry for that dyno but not chebby guys Smile
bigjohn2007
bigjohn2007
Post  mtacqua February 11th 2012, 11:08 pm
very nice, someday I'd like something like that.
mtacqua
mtacqua
Post  Kevin323K February 20th 2012, 12:16 am
That motor is bad AZZ.
Kevin323K
Post  badmach June 29th 2012, 12:36 am
just a small update Steve Morris came down with Ron from clocksoff racing and we did a few test runs in the old mach1 best time leaving REAL easy 8.40@191mph on the radials with 17lbs of boost leaving on 2 lbs . we also found out we had a cracked head trickflow said they had this happen before on a turbo build and its a problem with bolt stretch and 2 diff sized bolts. So we are bolting on a set of badass heads from Tony Bischoff and changing out rearend gear and we will hopefully be testing next week in MI
badmach
Post  bruno June 29th 2012, 8:56 am
badmach wrote:just a small update Steve Morris came down with Ron from clocksoff racing and we did a few test runs in the old mach1 best time leaving REAL easy 8.40@191mph on the radials with 17lbs of boost leaving on 2 lbs . we also found out we had a cracked head trickflow said they had this happen before on a turbo build and its a problem with bolt stretch and 2 diff sized bolts. So we are bolting on a set of badass heads from Tony Bischoff and changing out rearend gear and we will hopefully be testing next week in MI
wow those numbers are insane , good luck with getting things fixed ...it will be a monster once things get lined out Twisted Evil
http://WWW.CKRME.COM
Post  '65 T-BOLT June 29th 2012, 10:20 am
insane...insane in the membrane!
'65 T-BOLT
'65 T-BOLT
Post  whatbumper June 29th 2012, 3:43 pm
We've broken a lot of trick flow heads. We are not using them with boost anymore. I will run them with nitrous though!
This is a badass build. Looking forward to seeing more about it in the future.
Post  res0rli9 June 29th 2012, 7:44 pm
whatbumper wrote:We've broken a lot of trick flow heads. We are not using them with boost anymore. I will run them with nitrous though!
Why do they brake with boost?.....Will they brake with 10lbs. or less.
Post  whatbumper June 29th 2012, 10:38 pm
I doubt 10 pounds would be any worries. It was the 28+ lbs that were killing them.
Post  dtimmer June 29th 2012, 11:45 pm
please tell me you'll be testing at Martin or Milan. If so when? I'd love to check this thing out.
dtimmer
http://www.visnerengine.com/
Post  Frank Kramer June 30th 2012, 2:58 am
whatbumper wrote:I doubt 10 pounds would be any worries. It was the 28+ lbs that were killing them.
We are running more then 30 psi on them in our supercharged alcohol engines.
https://www.youtube.com/user/seasideaffair
Frank Kramer
Frank Kramer
http://www.seasideaffair.com
Post  whatbumper June 30th 2012, 10:13 am
I bet you could go even higher than that and be okay with your blowers and be fine. If I were to go to a roots or screw blower I would mind trying the trick flows again. And I know plenty of guys running the tfs heads with great reliability just wouldn't work out for us.
I'm not trying to bash the heads, just warning people the issues we've had.
Post  2POWERADDERS January 20th 2013, 11:21 am
thats out of control! Very Happy
2POWERADDERS
2POWERADDERS
Post  bigjohn2007 May 11th 2013, 11:13 am
If it had wing it will fly Cool
bigjohn2007
bigjohn2007
Post  738drvr October 1st 2013, 11:35 pm
Talked to Steve Morris at Dragweek. Car is having tranny/converter issues. Hope to have it sorted and out before the end of the season. Steve said the car is super nice and very comfortable on the street. Once sorted it will FLY. Low 7's on leafsprings. WOW!
Post  jason August 19th 2015, 12:34 am
So what heads would be good for 2,000 hp+ and 30 pounds of boost?
jason
jason
Post  738drvr August 19th 2015, 3:34 pm
The guy's name is Steve Ayesh and he's out of Wichita, KS. Here's a link to the history on the car:
http://www.yellowbullet.com/forum/showthread.php?t=473388&highlight=3000+horsepower+mustang&page=81
He had a grudge race with Larry Larson last month for 5K at his home track(Steve's). Here's the video:
https://m.youtube.com/watch?v=LdRHU8uOJdQ
Super bad car that has had lots of problems. Steve has dumped a lot of money in it and I'm amazed he's still wrestling with it. He has a lot of amazing Ford's at home in the shop.
I believe he owns the dragstrip in Wichita. Hope to meet him someday.
BTW, he beat Larson by 7 hundreths.
Post  Mark Miller August 20th 2015, 10:18 pm
738drvr wrote:The guy's name is Steve Ayesh and he's out of Wichita, KS. Here's a link to the history on the car:
Thanks for the Video 3rd times a charm for staging i guess!!!! Very Happy Very Happy Very Happy
Post  FalconEh August 20th 2015, 11:04 pm
Killer Mach Cool , if it had the equal weight it would not have been 7/100's 1500 lbs is like dragging an altered behind you or opening your chutes at the 330'
Let off before the 60' and got back on it for the W
Post  738drvr August 21st 2015, 12:58 am
I was actually surprised he beat Larson. Larry is one of the best racers at the track and that Chevy II is well sorted. Notice how soft they both had to leave. I know there had to be a lot of satisfaction for Steve. That car is a one of a kind and beautiful but he has had big problems with it. I think a lot of Steve Morris but he really flubbed this one up. It took Steve A. a lot of money and a lot of different people after Steve M got through with it to finally get it sorted and reliable.
Well over 100k in that Mach 1.
Post  nitrous.f October 25th 2015, 10:05 pm
know iam late but man did not know that these eliminator blocks and a460 heads can take much power! Shocked I have the premier block and a460 heads to!
nitrous.f
nitrous.f
Post  Mark Miller October 26th 2015, 1:15 am
738drvr wrote:I was actually surprised he beat Larson. Larry is one of the best racers at the track and that Chevy II is well sorted.  Notice how soft they both had to leave. I know there had to be a lot of satisfaction for Steve. That car is a one of a kind and beautiful but he has had big problems with it. I think a lot of Steve Morris but he really flubbed this one up. It took Steve A. a lot of money and a lot of different people after Steve M got through with it to finally get it sorted and reliable.
I see he ran a 7.25@190 mph letting out early,that's really hauling the mail at 4,200 lbs!!!! Smile Smile Smile
Post  738drvr October 26th 2015, 2:12 am
Mike Murillo runs twins on a BBF with A460 heads. He can go over 40# of boost and has run deep in the 6's at well over 200mph.
Them A460's are some bad heads fo sho.
