max spray on ten bolt head
whats the max anyone has sprayed on a a460 ten bolt head over 400 or not
oldracer65- Posts : 4
Re: max spray on ten bolt head
Everytime we sprayed 300 h.p. on kristinas a 460 10 bolt heads you could see water misting out of the motor from about half track on. we re torqued the heads then we tried new cometic gaskets, re surfaced the heads but it always lost water. went back to 200 h.p. and it was happy then. todd
dadof384k- Posts : 46
mine are not a460 but i would say my edelbrocks have the weakest deck surface (cylinder head gurus correct me if im wrong ) and at the bash 2 years ago i ran with both kits which was about 400 ...... Ive been working on my first kit lately which is between 200 and 250 with no issues and this weekend we will be bringing in the 2nd stage anywhere from another 150- 300 .... i would venture to say its all about the tune
and i also run cometics and have only torque them down once
bruno wrote:mine are not a460 but i would say my edelbrocks have the weakest deck surface (cylinder head gurus correct me if im wrong ) and at the bash 2 years ago i ran with both kits which was about 400 ...... Ive been working on my first kit lately which is between 200 and 250 with no issues and this weekend we will be bringing in the 2nd stage anywhere from another 150- 300 .... i would venture to say its all about the tune
I have run this same head with 42 pills in the fogger never had a problem but my tune ups are very close.(started with 28s in the fogger and worked up) No detonation and low timing on motor
i run small block ford and trying 28s on the first kit and 26s in the second kit and maybe more this weekend. I dont care if its got 40 head bolts you detonate it and its coming off.
studly- Posts : 512
» coolant leak between head and block at head bolt location.
» Head bolt?????
» 10 bolt head
» Cometic MLS head gaskets
» A460 short deck block, truck pullers c460
» Head bolt?????
» 10 bolt head
