10 bolt head
10 bolt head Empty 10 bolt head
Post  460bronco July 17th 2016, 11:01 am
Which 10 bolt head works the best with nitrous? P-51? Tfs? AFR? Beside the number of head bolts and clamping force of the head, what limits the level of nitrous that can be used with this class of cylinder head?
460bronco
460bronco
10 bolt head Empty Re: 10 bolt head
Post  richter69 July 17th 2016, 1:42 pm
The thicker the deck the better off you are, that said Ive been spraying a set of P51s w two kits for over 3 seasons w no issues.... Tune has a lot to do w it.
Post  460bronco July 17th 2016, 5:44 pm
Does the SCJ have a similar deck thickness?
460bronco
460bronco
Post  NoSlo5.0 July 25th 2016, 5:55 pm
richter69 wrote:The thicker the deck the better off you are, that said Ive been spraying a set of P51s w two kits for over 3 seasons w no issues.... Tune has a lot to do w it.
Not two kits but one good size one and no issues.. Spray away just be good with the timing..
NoSlo5.0
Post  460bronco July 25th 2016, 9:14 pm
If one was to build a 850-900hp  p-51 headed engine around 550 inches.  Would it be feasible to spray to 1500 total package? Trying to do something different in an outlaw 200' dirt drag class.
460bronco
460bronco
Post  NoSlo5.0 July 25th 2016, 9:28 pm
ive sprayed a 60 jet on mine.. no issues
NoSlo5.0
