Head bolt question
Head bolt question
Can stock hesd bolts be used on aluminum a429 heads without washers?
mustangjeff- Posts : 87
Re: Head bolt question
You CAN do anything you like. Studs are the way to go, but every nut or bolt needs a washer.
ribald1- Posts : 11
mustangjeff wrote:Can stock hesd bolts be used on aluminum a429 heads without washers?
You need harden washers. and you can use the stock head bolts.
res0rli9- BBF CONTRIBUTOR
» coolant leak between head and block at head bolt location.
» 10 bolt head
» Head bolt?????
» 18 head bolt torque plate
» Stripped Head bolt
» 10 bolt head
» Head bolt?????
