Ring filing
+6
NO FAIR
tall69
Larry T
72mav
10 posters
Ring filing Empty Ring filing
Post  bbf-falcon September 15th 2009, 6:46 pm
I file cut rings for about 2 hrs. today. While I was making sure they were square, my little PEE brain got to thinking. If I put enough clearance in them so they don't BUTT together after they are at MAX heat, What makes the difference if they aren't perfectly square if they aren't BUTTED together anyway Rolling Eyes
Ring filing Empty Re: Ring filing
Post  72mav September 15th 2009, 7:17 pm
I think you just answered it Rick. When the thermal expansion occurs they do separate.
IMO,i dont think its a issue. Ill probably get flamed for this one though. Laughing
72mav
72mav
Post  the Coug September 15th 2009, 8:20 pm
Rick give it a little more clearances incase you decide to giggle juice it later....
Post  Larry T September 15th 2009, 9:18 pm
i dont mean to second guess you but have you read the instructions and under stand how to get the recomended clearance for the intended use Smile i just dont want you thinking a little tighter is better,broken rings suck...i use a piston to square the ring in the bore and check the clearance.as randy said clearance the rings for nitrous just in case.i did this on my motor all though i may not ever do it.
as for the squareness do it as best as you can.other wise i think we all would have to buy a special machine to grind them perfect Smile
Larry T
Larry T
Post  tall69 September 16th 2009, 11:15 am
Think about this exaggerated example, if both sides were cut at a 45 degree angle, your minimum clearance would have to be measured from tip to tip right? Just think how much blow by there would be because the rest of the ring was back cut. A good square cut means you have your minimum clearance AND maximum seal. Make sense?
tall69
tall69
Post  NO FAIR September 16th 2009, 1:23 pm
But in a "Total Seal" piston ring the top ring is cut at a 45 degree angle, but it is also rotated 90 degrees from the ring that it sits on, so I wonder if it matters.
Just a thought
Neutral
NO FAIR
NO FAIR
Post  tall69 September 16th 2009, 2:51 pm
NO FAIR wrote:But in a "Total Seal" piston ring the top ring is cut at a 45 degree angle, but it is also rotated 90 degrees from the ring that it sits on, so I wonder if it matters.
Just a thought
Neutral
True. I was saying if the angles were both back cut in opposite directions.
tall69
tall69
Post  bbf-falcon September 16th 2009, 2:52 pm
I really don't think any of you understood a word I said. Rolling Eyes What I mean is, I know that we need to strive to get the rings clearanced to as close as we can w/out butting up under extreme heat,BUT I want my ring gap wide enough so they don't BUTT together under any circumstance,so if they have a gap, what makes a difference if they are PERFECTLY square or not.
And Larry, I'm not talking about SQUARE in the Bore No
Post  NO FAIR September 16th 2009, 3:01 pm
I think it is almost impossible to get them perfectly square on both sides of the cut. I think at the smallest point of the taper on your cut you meet the manufactures minimum clearence for your set up ( street or race only ect) you should be fine. What I can tell you when I did mine the very first piston took the longest.
NO FAIR
NO FAIR
Post  bbf-falcon September 16th 2009, 3:13 pm
I've already got them done,and they are as square as they can be, I've done these things alot of times, and they go fairly quickly now. I was just thinking out loud Rolling Eyes My mind likes to wonder some times. Laughing
Post  D. Sea September 16th 2009, 3:14 pm
bbf-falcon wrote:I've already got them done,and they are as square as they can be, I've done these things alot of times, and they go fairly quickly now. I was just thinking out loud Rolling Eyes My mind likes to wonder some times. Laughing
That happens to me all the time Rick tongue
D. Sea
D. Sea
Post  bbf-falcon September 16th 2009, 3:19 pm
Laughing Laughing Laughing
Post  IcallhimGeorge September 16th 2009, 3:20 pm
This makes me feel a little better. I did my best to have them perfectly square while staying within spec for gap. A couple may have been off a little bit but pretty close I think. I was more concerned with having the gap all uniform.
I gapped mine for a 150shot per total seals specs (cant remember exactly what it was off the top of my head) and I didnt think they'd ever touch. I guess we were thinking along the same lines.
IcallhimGeorge
IcallhimGeorge
Post  bbf-falcon September 16th 2009, 3:24 pm
I don't plan on ever running any squeeze. My bore is 4.440 and I set the top at .018 and 2nd at .022.
Post  kim September 16th 2009, 6:40 pm
damn them are tight...
kim
Post  richter69 September 16th 2009, 6:58 pm
I ended up .020 and .024 on a 4.42 bore, considered that borderline on the tight side. I guess it depends on the ring material etc.
Post  bbf-falcon September 16th 2009, 8:25 pm
I went by the instructions on the Ackerly& Childs ring set. They said 22 on 2 and 17 on top. Non asperated Gas/Alcohol
Post  D. Sea September 17th 2009, 12:00 pm
That's about where I have mine. IIRC it's .019 on top and .022 on bottom.
D. Sea
D. Sea
