Do they make a ductile Iron ring 5/64 X 4.39 bore or whats a good ring?
Used to see Speeedpro around in 4.39 sizes left over. With all the changes Clevite/Mahle and such thought there bee a small chance someone making a performance ring for the 5/64 and .030 overbore. Just got some new OLD stock 429 forgings , with 11 to one would like a good ring.
ED468- Posts : 200
Re: Do they make a ductile Iron ring 5/64 X 4.39 bore or whats a good ring?
You can always try Total Seal - if they don't have it, they can probably make it.
pmrphil- Posts : 170
Sealed Power and Total Seal both have them. Ordered a set of both in the last couple months through Summit.
fordguy69- Posts : 98
I've seen them in the past on summit, tried looking them up and figured they sold outnew old stock..,Thanks I call.
Plasma moly rings What i'm looking for with ductile top ring thanks again.
ED468- Posts : 200
ED468 wrote:Plasma moly rings What i'm looking for with ductile top ring thanks again.
Personally, I would use a Total Seal "Ring spacer" with a 1/16" or .043" ring
Speed Pro "E296K +.030" cheap from Summit.
gt350hr- Posts : 662
gt350hr wrote:Speed Pro "E296K +.030" cheap from Summit.
That ring set has a moly top ring but, it is not "Ductile Iron". Merely a cast iron, moly ring.
» Do make a ring set for .060 piston that i would not have to file fit
» Will Ductile iron rings work OK here?
» whats the largest bore for a D1 block?
» anybody still use iron heads to make horsepower?
» Looking for 4.450 bore piston ring package?
