Will Ductile iron rings work OK here?
I have all my parts and fresh hone job. Honed for moly-faced ring. 15.2 to 1 comp ratio, hi dynamic ratio, 118 racing fuel. Radiator and fan, electric water pump. All iron engine. 5700-5800 rpm, 15 seconds under load. 35-40 runs per summer. Will a ductile iron ring be sufficient here?
Perry
Perry
hpwdboss1- Posts : 147
Re: Will Ductile iron rings work OK here?
moly will give better service life
Frank Merkl- Posts : 1524
and seal
Re: Ductile ring
Just trying to figure if a moly faced , ductile iron ring will take the heat. I know I need the moly face, but will the ductile iron be up to the task? Back in the supercharged alky
days we used steel rings, but this isn't on that kind of budget, hopefully.
Perry
![cherry](https://2img.net/i/fa/i/smiles/icon_cherry.png)
Perry
you will be more than ok with ductile top ringshpwdboss1 wrote:Just trying to figure if a moly faced , ductile iron ring will take the heat. I know I need the moly face, but will the ductile iron be up to the task? Back in the supercharged alkydays we used steel rings, but this isn't on that kind of budget, hopefully.
Perry
DanH- Posts : 1081
Ductile top rings
That is what I have been wanting to know
I have a set of file fit on hand and didn't want to put em in if they wouldn't last. thanks again guys.
Perry
![cheers](https://2img.net/i/fa/i/smiles/icon_cheers.png)
Perry
» Do they make a ductile Iron ring 5/64 X 4.39 bore or whats a good ring?
» used Kb hypers 206 - .030 over psitons , new rings , pins and lock rings
» will tfs A460 heads work on my d1ve block ? or do they only work on the race blocks
» piston rings
» Getting ready to pull the 429 CJ...Need advice!
» piston rings
