restricting oil at the lifter crossover tower
restricting oil at the lifter crossover tower Empty restricting oil at the lifter crossover tower
Post  manofmerc November 18th 2011, 7:47 am
I pulled my engine down for a freshen up .This is a 466 bracket car.My #7 rod bearing was showing some copper the rest of my bearings looked fine nothing like #7.Several years ago on my first pass with this engine I spun #7 rod bearing .A new rod(scat h beam)crank turning I was in business .This engine is 5 years old .I have the milidon 8 qt pan melling hv pump .The drain holes in the block have been chamfered .Rod and main clearances were all in the .0027 .003 Checked with a dial bore gauge .I really dont rev this engine to high normally 6000 is the max .On test days maybe 6500 at the end of the 1/4.What about this crossover mod ? Dont you restrict the oil going to the drivers side lifter gallery ? My cam is a solid flat tappet .If this is the case what size hole is drilled in the restrictor? Or does everybody have another idea.I have good idle pressure 40 lbs and 60-70 at the end of the track never any flucations .vr1 oil 20-50 good k/n filter Thanks guys Neutral
manofmerc
restricting oil at the lifter crossover tower Empty Re: restricting oil at the lifter crossover tower
Post  dfree383 November 18th 2011, 9:19 am
is it the only one doing it? can you post pictures of the bearings?
Post  jesse November 18th 2011, 12:57 pm
you need green oil lol
your combo should not need any oil mods
there are motors out there spinning alot more
rpms than yours and have ne issues
i would say have the rod checked and crank
again.
jesse
jesse
restricting oil at the lifter crossover tower Empty Yes it is
Post  manofmerc November 18th 2011, 5:48 pm
Yes dfree#7 is the only one doing this .And no I cant post pictures .Looking at my crank #4 main journal supplies oil to two rod journals And I have read on the other forum #7 is the last in line for oil .One other thing I forgot in my first post I am using half groove main bearings .It seems I cant get full groove main bearings anymore .Summit doesnt carry them and barnett performance cant get them either .I went over my notes when I assembled this engine and all of my clearances were in the .0027-.0033 range .Thanks guys maybe I need some green oil huh!
manofmerc
Post  res0rli9 November 19th 2011, 4:27 am
You can get 3/4 bearings
