how much hp on stock block?
yellowhorse7
stanggt
How much power will a stock D1VE 460 block handle? should it be filled half way? I want to turbocharge it. going to build a 521. Thanks
stanggt- Posts : 494
Re: how much hp on stock block?
What turbos or turbo?
whatbumper- Posts : 3024
stanggt wrote:How much power will a stock D1VE 460 block handle? should it be filled half way? I want to turbocharge it. going to build a 521. Thanks
Upwards of a 1000 on a single plate.....
yellowhorse7- Posts : 1382
yellowhorse7 wrote:stanggt wrote:How much power will a stock D1VE 460 block handle? should it be filled half way? I want to turbocharge it. going to build a 521. Thanks
you dang nitrous guys
lol, not that plate turbo, the round thingy that whistles.lol seriously, will they handle 1000-1200 hp on lets say 15 pounds of boost or so?bruno wrote:yellowhorse7 wrote:stanggt wrote:How much power will a stock D1VE 460 block handle? should it be filled half way? I want to turbocharge it. going to build a 521. Thanks
stanggt wrote:lol, not that plate turbo, the round thingy that whistles.lol seriously, will they handle 1000-1200 hp on lets say 15 pounds of boost or so?bruno wrote:yellowhorse7 wrote:stanggt wrote:How much power will a stock D1VE 460 block handle? should it be filled half way? I want to turbocharge it. going to build a 521. Thanks
Yes they will live but you'll need to take care to not spin it to the moon. DO NOT DETONATE IT! Use a minimum of a girdle but splayed caps would help. Even still It will have some cap walk but that's the nature of the block. Use good head studs. Don't hillbilly it up. Contact BOSS 429 on here and he'll give you the best advice possible
Lol. We are a bit off
cool,thanks yellow,Id be happy with 1000hp out of it, wont be raced and ran hard that much,probly keep rpms about 6k.
I made a tick over 1000 on a unfilled 2 bolt D9 block with a relatively aggressive tune on a single plate at 460 inches. Boost is a little friendlier and build more linear so i would venture to say 1200 hp is within the realm of possibility, probly even reliably. You WILL have cap walk, but if you keep an eye on it and the bearings look good who cares.
is cap walk from the power being generated through the crank what makes that happen or higher rpms? Or both? I cant imagine that I will need to put alot of boost to the 521 to make that power.
Cap walk is the effect of the cap bending in the middle and scrubbing itself on the block. It happens because of quite a few things, especially detonation. There are ways to limit it, 4 bolt splayed caps being the best.
schmitty- Posts : 4538
thats good to know, I may just add the caps when building motor then. thanks schmittyschmitty wrote:Cap walk is the effect of the cap bending in the middle and scrubbing itself on the block. It happens because of quite a few things, especially detonation. There are ways to limit it, 4 bolt splayed caps being the best.
I have a half filled c8 block, if you want to start with this?
I'm in Belleville MI...
adam
blown86hallet- Posts : 1012
» question about stock 1971 stock block
» Differences between stock type block and the a460 block?
» Backup motor build under way...soon as the snow clears
» Looking for stock 460 block
» Stock block max H/P
