nodular cast crank?
nodular cast crank? Empty nodular cast crank?
Post  stanggt November 26th 2011, 11:18 am
wondering how much (max)power a nodular cast scat crank will handle ?
stanggt
stanggt
nodular cast crank? Empty Re: nodular cast crank?
Post  dfree383 November 26th 2011, 12:25 pm
In factory stroke and journal size, More than the factory block........
Post  Paul Kane November 26th 2011, 1:17 pm
stanggt wrote:wondering how much (max)power a nodular cast scat crank will handle ?
In the right build, right applicaton, and in the right hands, 4-figure horsepower is possible. In the wrong hands/wrong build/wrong application, it is not.
Paul
Post  stanggt November 27th 2011, 9:11 am
thanks for info, guess I buy forged crank.
stanggt
stanggt
Post  dfree383 November 27th 2011, 9:35 am
What are you looking to build?
Post  stanggt November 28th 2011, 1:12 pm
dfree383 wrote:What are you looking to build?
twin turbo 545.
stanggt
stanggt
Post  dfree383 November 28th 2011, 3:07 pm
The Chinese cast stroker cranks are not good for real high HP builds, You need to look into a 4340 forging, the Chinese forgings are acceptable but most makes require remachining them to make them right, better choice is something like a Bryant, the forging and finish are top rate.
Post  stanggt November 28th 2011, 8:48 pm
dfree383 wrote:The Chinese cast stroker cranks are not good for real high HP builds, You need to look into a 4340 forging, the Chinese forgings are acceptable but most makes require remachining them to make them right, better choice is something like a Bryant, the forging and finish are top rate.
I ended up getting the Crower billit crank and child & Alberts rods back from the guy who bought it from me Twisted Evil and decided to build me a monster. Gunna get me an A460 block in January, just need to find some lower compression pistons for the set-up.
stanggt
stanggt
Post  dfree383 November 28th 2011, 8:53 pm
Your on the right track.
Post  dexter532 November 29th 2011, 9:30 pm
You might want to talk to Gold at Fastlane machine in Orem UT. He just built a low compression 600 for twin turbos. Had to custom design the pistons through diamond for the tight A head chambers and still have room for boost. Very cool looking piston. Deep dish you could eat cereal out off in the morning. I believe he was over 800 on the dyno naturally aspirated.
dexter532
