who has the "Magic Heads"
+7
138
Tennessee Bullitt
Larry T
11 posters
who has the "Magic Heads" Empty who has the "Magic Heads"
Post  Larry T November 28th 2011, 2:25 am
the Duck on yb is wineing that the bbf & bbc conventional heads are now flowing over 500cfm and takeing over the x275 radial classes previously dominated by the sb.the word is they are running low 4.7d's and the sb's are about maxed out with the current head rules.this is with 1 nos system plate or fogger no progressive etc.
the bbf a460 heads are what has been mentioned the most at 500 or above cfm.is any one here getting that kind of flow from the A heads?i read were blakes p51's have 425-430 cfm is this the max that can be achieved?
i have been watching these classes for a while now and seeing the bb stuff making a showing.team Z has had a hand in helping them get their suspension dialed in with a low 1.xx 60ft.
Larry T
Larry T
who has the "Magic Heads" Empty Re: who has the "Magic Heads"
Post  bruno November 28th 2011, 7:25 am
Larry T wrote:the Duck on yb is wineing that the bbf & bbc conventional heads are now flowing over 500cfm and takeing over the x275 radial classes previously dominated by the sb.the word is they are running low 4.7d's and the sb's are about maxed out with the current head rules.this is with 1 nos system plate or fogger no progressive etc.
if the a460 cylinder head was "THE" head you had to use in your class and money was no object , achieving over 500 cfm would be attainable
http://WWW.CKRME.COM
Post  Tennessee Bullitt November 28th 2011, 9:25 am
well tell him if his small block isn't cutting it give Lem a call he will hook him up... Very Happy
Tennessee Bullitt
Tennessee Bullitt
Post  dfree383 November 28th 2011, 9:36 am
So build a better small block....... Suspect
Post  rmcomprandy November 28th 2011, 11:45 am
The "A" heads from IDT will get to that air flow rather consistently. However, you will need to use almost an inch of valve lift.
You're not going to get anywhere near the "A" head with a P-51. However their best airflow is NOT above .750" valve lift.
Post  whatbumper November 28th 2011, 1:03 pm
dfree383 wrote:So build a better small block....... Suspect
they just can't take the amount of nitrous and live very long. the 10 head bolts don't help much either. big blocks are the only way to go in a head limited class.
Post  dfree383 November 28th 2011, 1:05 pm
Exacary........
Post  138 November 28th 2011, 1:43 pm
he's a smart dide, and just flappin gums to keep his series alive and growing...job security. whats the largest/ higest flowing conv. chevy head they are allowing anyway?
138
Post  dfree383 November 28th 2011, 1:52 pm
Conventional is a wide open term in the GM camp......
Post  bruno November 28th 2011, 2:15 pm
138 wrote:he's a smart dide, and just flappin gums to keep his series alive and growing...job security. whats the largest/ higest flowing conv. chevy head they are allowing anyway?
rfd has several 24* heads that flow over 500 ......... but there are only 2-3 companies that advertise those numbers , but i assure yall that all the heavy hitters are flowing well over 500 cfm on ther " conventional heads "
and i have no doubt in my mind that if i gave Evans 10 stacks and a set of tfs a heads that it could be done Wink
Post  138 November 28th 2011, 2:28 pm
10 stacks for a set of heads to throw on a bicycle tire...what a joke... Fun to watch though.
138
Post  richter69 November 28th 2011, 2:36 pm
honestly I dont see how an A460 is conventional........
Post  dfree383 November 28th 2011, 2:44 pm
richter69 wrote:honestly I dont see how an A460 is conventional........
Its as conventional as any of the Chevy heads....
Post  richter69 November 28th 2011, 2:50 pm
thats my point
Post  bruno November 28th 2011, 3:04 pm
thats the whole point of his "Donald's" thread !!!! the so called "conventional " heads are faster then the Big Chief stuff .........
but rules are rules ....
Post  whatbumper November 28th 2011, 3:23 pm
When the rules were written it was the only thing that would compete with the chebby stuff. I have personally seen some of the new chebby edelbrock stuff go in the 525-530 range.
How about we do like some tractor pulling classes and put an RPM limit on them and give them the chip to do it. lol!
Post  138 November 28th 2011, 3:25 pm
so how are A heads better than BC's... I thought they were more like a C head type deal..
138
Post  138 November 28th 2011, 3:28 pm
Not to mention anything chevy has like 5000 intakes, and all kinds of block options...
138
Post  bruno November 28th 2011, 4:15 pm
138 wrote:so how are A heads better than BC's... I thought they were more like a C head type deal..
they are winning more races Very Happy ......
put a 500 shot on a 510 cfm a-head and put a 500 shot on a 550 cfm Big Chief which one is faster ? on a 10.5" tire Razz Razz
Post  138 November 28th 2011, 4:40 pm
That sounds a little odd... But ok.
138
Post  Larry T November 28th 2011, 7:02 pm
A ten stack thats nothing to these guys who can afford it especially when the purse is 3-4 times that.
So no one is admitting that they are running the "MAGIC HEADS" here?remember this is on a 4500 single cast intake Very Happy
Larry T
Larry T
Post  dfree383 November 28th 2011, 7:06 pm
138 wrote:That sounds a little odd... But ok.
dry flow isn't everything..... combustion chamber, valve placement, sparkplug location, dome size, ect all come into play. its much more scientific the "My heads flow more than yours"
Post  Lem Evans November 28th 2011, 8:18 pm
dfree383 wrote:Conventional is a wide open term in the GM camp......
I'm aware of the rock'n conventional bbc heads. The conv. bbc heads are defined in most rule books as something not less than 23*ish valve angles. Otherwise there is not much "conventional" about them. One inch lift cams etc. are required to make them the most effective. A set is coming down this way for a bbc unpaved track vehicle. Two things you can count on......I'll get them on the flow bench & a very good set of C460 heads/manifold could be cheaper.
Magic and money both start with a "M".
Post  cool40 November 28th 2011, 9:40 pm
my IDT heads flowed 498 @ .900 on a 4.500 bore.i'd think on a 4.625 they'd do more,which IDT said 511 on 4.625. one thing i've heard the local chevy guys talk about is needing a big core cam.they spend a lot just to have a cam of much size.lol. i heard of one guy who took a chevy/olds block of some sort,aftermarket anyway,and had the headbolt holes located for EX514 heads.then he got a chevy intake,it was cast i know,and cut it all up to fit the ex heads.the chevy guys were bitchen about it having ford heads.lol.....and it wore their asses out at the truck pull too. Laughing
Post  Lem Evans November 28th 2011, 10:30 pm
Like Al Neal said.......how did it run?
