t-bird owners
70429scj
t-bird owners Empty t-bird owners
Post  70429scj November 28th 2011, 7:32 pm
What is the correct factory length on rear lower control arms.
Thanks,
Steve
70429scj
70429scj
t-bird owners Empty Re: t-bird owners
Post  dfree383 November 28th 2011, 7:46 pm
What year?
t-bird owners Empty 1988
Post  70429scj November 28th 2011, 8:02 pm
1988
70429scj
70429scj
Post  dfree383 November 28th 2011, 8:09 pm
aren't they the same as a mustang?
t-bird owners Empty no
Post  70429scj November 28th 2011, 8:26 pm
No they are not the t-birds are longer some guys have said using the mustang type will pull the rearend 1 inch forward. Not looking for more headaches going to a lower soild bar and coilover shock setup this winter.
Steve
Last edited by 70429scj on November 28th 2011, 9:41 pm; edited 2 times in total (Reason for editing : spelling)
70429scj
70429scj
Post  whatbumper November 28th 2011, 9:23 pm
We have always used the exact same parts. Always had great luck.
Post  Mark Miller November 28th 2011, 11:39 pm
70429scj wrote:No they are not the t-birds are longer some guys have said using the mustang type will pull the rearend 1 inch forward. Not looking for more headaches going to a lower soild bar and coilover shock setup this winter.
Steve
I think the 83-86 T-Bird rear control arms were the same as the Mustang.But like you said i'm pretty sure the 87-88 T-Bird were different.
Later Mark.
Post  Barney November 29th 2011, 12:27 pm
You could always get adjustables and put them at whatever length you'd like,
Barney
Barney
Post  whatbumper November 29th 2011, 12:48 pm
Steve
Later Mark.
they should be about 1/4-1/2" longer. Can't remember. We use adjustable lowers on everything and push the rear back an inch anyway so I guess I never really noticed the difference.
t-bird owners Empty rear
Post  70429scj November 29th 2011, 1:44 pm
Heres my pain in the but. My bird when i bought it had ss lower contol arms on it and the had fabed a bracket
to mount them. So right off the bat I don't know what the correct lenght is supposed to be. I do have a set of adjustable lowers but I have no referance point to start with. maybe these pics will help. the mustang wheelbase 100.5 where the bird is 104.2 wheelbase
[img]t-bird owners Tbird021[/img]
[img]t-bird owners Tbird020[/img]
t-bird owners Tbird016
t-bird owners Tbird012
Last edited by 70429scj on November 29th 2011, 2:42 pm; edited 1 time in total (Reason for editing : spelling)
70429scj
70429scj
t-bird owners Empty parts
Post  70429scj November 29th 2011, 2:31 pm
mustang and T-bird owners can still get most of D&D suspension parts from. I hope this helps someone!!!!
Brandt Racing Enterprises
42211-B Sierra Highway
Lancaster CA 93535
661-723-2273
www.brandtracing.com
70429scj
70429scj
Post  bigblock t-bird November 29th 2011, 8:28 pm
Just checked the 8.8 out of my 88 TC T-Bitd. 18" from center to center of bolt holes. Hope this helps. Steve www.classicgearjammers.org
bigblock t-bird
t-bird owners Empty cool
Post  70429scj November 29th 2011, 11:13 pm
The new lower control arms measure 18" center of bolt to center so that will be the starting point. Can't say thanks enough for the help.
Steve
70429scj
70429scj
Post  whatbumper November 29th 2011, 11:16 pm
Most mustangs are really 101. Ours was 102". As far as length is concerned you can make them any length that you want. Put the rear in the wheelwell and make sure the rear is square then adjust the top accordingly.
t-bird owners Empty Question
Post  70429scj November 29th 2011, 11:47 pm
anybody here running the rear coil over conversions on there fox body mustang. Trying to make this project payoff as much as possible before we put some real BBF power to this bird.
Thanks,
Steve
70429scj
70429scj
Post  bigblock t-bird November 30th 2011, 8:45 pm
I used Autowelds coil over set up. Qa1 and there S99 9". If you plan on BBF you will be far ahead to go with a 9", mini tubs,coil overs and ladderbars. It may be alot of $$$, but well spent money. Steve
bigblock t-bird
Post  whatbumper November 30th 2011, 10:24 pm
bigblock t-bird wrote:I used Autowelds coil over set up. Qa1 and there S99 9". If you plan on BBF you will be far ahead to go with a 9", mini tubs,coil overs and ladderbars. It may be alot of $$$, but well spent money. Steve
I disagree with ladder bars. Stock suspension is too good to go away from. It would be a good idea to ditch all of the solid stuff and go fully adjustable lower and most importantly uppers.
Post  dfree383 November 30th 2011, 11:55 pm
I've ran the rear coilover conversions in a couple of fox mustangs, they worked great. You can get a variety of spring rates and they allow some preload to be in too, it gives you alot of flexibility IMO.
t-bird owners Empty suspension
Post  70429scj December 1st 2011, 2:29 am
I have double adjustable on the upper and lower arms. Just was not sure how well the coil over setups where
working. I like the ideal of puting the shock and spring together behind the axle. the whole setup then works
like a 4 link car. I will also help buy being able to run a wider tire than 28x10.5x15. Getting the spring and shock combination correct mike be a headache. because I belive this has more tail overhang and a little more weight than a mustang. I had heard good and bad about the conversion kits. Anybody with any thoughts chime in please
Thanks,
Steve
70429scj
70429scj
Post  whatbumper December 1st 2011, 12:53 pm
I just built a car for a guy that is running 325 drag radials and 29.5w's and we used the Wolfe spring kit that kept the springs on the lower control arms and put the shocks behind the axle like what you are talking about. I like the Wolfe kits.
BTW the car that Wolfe ran still has the springs mounted on the lowers.
Post  jbozzelle December 4th 2011, 2:03 pm
70429scj wrote:Heres my pain in the but. My bird when i bought it had ss lower contol arms on it and the had fabed a bracket
to mount them.
That bracket is part of the SS lift bars. That's how they get them to work. Lowering the rear point will cause them to bite harder. If you have good fab skills just buy some tubing, tube adapters and rod ends and make what you need...
t-bird owners Empty ss
Post  70429scj December 7th 2011, 12:54 am
I was not aware that the backets came with the lift bars. I will have to brake out the trust grinder then!! Have now got the correct length bars lower bars double adjustable. Bought Autowelds spring mounting bracket to move the spring off the lower bar onto a spring pad in front of the rearend then probably Strange 10 way adjustable shocks behind the rearend. Not sure what spring rate is going to end up being. Well at least once
this is done maybe I can order a correct length driveshaft. Maybe Santa will bring me one even if it's used!!
Steve
70429scj
70429scj
