JW Ultracase owners..... question for you.
56Tbird
85montess
342g
D. Sea
JW Ultracase owners..... question for you. Empty JW Ultracase owners..... question for you.
Post  David Cole May 9th 2011, 12:34 am
For those of you that have a JW Ultra Case in a door car.... What transmission dipstick are you using? My car had a nice Lokar dipstick, but it won't work with the Ultra Case. The case is too thick just in front of the dipstick hole and the Lokar dipstick has large AN type fitting on the end just above the part that goes in the hole in the case. Simply won't fit.
JW Ultracase owners..... question for you. Empty Re: JW Ultracase owners..... question for you.
Post  D. Sea May 9th 2011, 12:32 pm
I think mine is a TCI unit from jegs that Bill ordered for me when I first got my trans. It's zinc plated and twist locks.
D. Sea
D. Sea
Post  342g May 9th 2011, 12:46 pm
Mine is from A.R.T. part#019633, worked perfect.
342g
342g
Post  David Cole May 9th 2011, 1:34 pm
Thanks guys,
Harold,
How does it mount to the case or bell? The pic on their website only shows the shorty version and it mounts with an adel clamp. Does the full length version mount the same way?
It looks like that might be what I need. Need to order some replacement wheels for my wheelie bars as well. They have both, so I would save on some shipping.
JW Ultracase owners..... question for you. Empty Dipstick
Post  85montess May 9th 2011, 2:18 pm
David,
The one that I ordered for Damon was just the long dipstick for a Chevy powerglide that had the twist lock on the top. It just has a rubber O-ring on it and it just slides into the case. The top bolt bracket was "adjusted" until it would line up with the Ford Pattern for the bellhousing bolt. I think that the hole needs to be opened up for the 7/16" bolt instead of the Chevy 3/8". The bellhousing bolt is what holds it in.
85montess
85montess
Post  56Tbird May 9th 2011, 3:41 pm
David ,I ground the side of my lokar down to fit my JW case.
56Tbird
56Tbird
Post  bruno May 9th 2011, 4:24 pm
56Tbird wrote:David ,I ground the side of my lokar down to fit my JW case.
i have a lokar deal in mine also
http://WWW.CKRME.COM
Post  342g May 9th 2011, 6:01 pm
IT comes with the clamp, just like the shorty, I had no trouble at all with mine, I moved the clamp up and mounted it to the mid plate.
342g
342g
Post  56Tbird May 10th 2011, 2:01 am
I thought Bruno and Harold both had stock cases with a JW ultra bell ??Maybe I'm wrong ...again...lol
56Tbird
56Tbird
Post  Wheelie58 May 10th 2011, 7:13 am
David,
As we discussed, the NHRA accepted Lokar Anchor Tight dipstick will fit your Ultra Case. There are about 8 part numbers, depending on color and mounting. Here is a link. http://www.lokarmotorsports.com/products-pages/flex-trans-dipstick.html
Summit had mine in stock...firewall mount, plain color.
It is very close to the case. I took about .100" off the release collar with a quick belt sand to provide clearance.
Keith
Wheelie58
Wheelie58
Post  whatbumper May 10th 2011, 7:36 am
Wheelie58 wrote:David,
Keith
that's the one we use for everything. we just use a dremel tool or a little belt sander to clearance tight fits. different castings even within the same brands of cases fit differently (imagine that)
Post  342g May 10th 2011, 11:37 am
56Tbird wrote:I thought Bruno and Harold both had stock cases with a JW ultra bell ??Maybe I'm wrong ...again...lol
You are right Dan, I reread the original post, rub out everything I said Dave, I only have the J.W. bell, sorry.
342g
342g
Post  BIGDOG466 May 12th 2011, 4:45 pm
Mine came from JW had to use a wire condiut clamp and hook it to the back of the intake.
BIGDOG466
BIGDOG466
