Hemi Twin Turbo Outlaw 10.5 Shelby build
+39
badsnake306
austin460
powerstrokeace
gordyd4
61coon
5pointslow
kim
bronco911
70FB
D-CEL
512Fairlane
D's557BBF
Tony M
nuclearcobra
Jim Brown
Tennessee Bullitt
yellowhorse7
bigblok2000ranger
badcoupe
psfracer
D. Sea
rodfarva
43 posters
Page 4 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 Empty Re: Hemi Twin Turbo Outlaw 10.5 Shelby build
Post  kim November 13th 2013, 10:54 pm
Disagree, only on the technicality that the Shelby's are limited production, so had it sat and rotted in a warehouse, it would one day sell for LOTS. For what he will keep of the Shelby, he'd have been further ahead getting a 6 cylinder car and buying the Shelby plastic.
Its his money, his car, and more power to him. Hell I'de volunteer to drive the pick-up around that carries his balls for a couple days, just to say I knew him.
kim
Post  supervel45 November 25th 2013, 4:49 am
psfracer wrote:Your article pretty much shows exactly why I went with the BBF also.  Not only are they much easier to work on vs the Mod motor, but, as your article shows, once you start really leaning on the little mod motor, it becomes pretty unreliable.   While my current set up is no faster then what a mod motor could do with a lot of boost, it is certainly more reliable, as I make pass after pass without failure, all motor, in the 9.40s at 3420lbs.
I think in the end you are making the right choice, as the big block ford should give you the power you are looking for and do so with reliability.  Of course as long as its built right, which would apply to any motor.
With Out even pushing it hard. From what I have read you have alot left, if you want to go Faster. Have not seen any 572ci mod motor's either, no subs. for cu. inches, when it comes to durability, and horepower. We just need the cyl. heads to match the cid in airflow, that the mod motors have, and it would not even be a race. The weight difference in all alum. motors would be negliable, compared to the HP output. Same with Chevy and the Mavk IV BB vs the Ls motors.
Post  jasonf November 25th 2013, 2:01 pm
kim wrote:
Hell I'd volunteer to drive the pick-up around that carries his balls for a couple days, just to say I knew him.
Hahahahahahahahahahahahahahahahahahaha
Post  5pointslow November 26th 2013, 8:29 am
couldnt you just have cut up a v6 car that same year and change some body panels and cloned the shelby ?
some say you have balls ....some will say otherwise
5pointslow
5pointslow
Post  5pointslow November 26th 2013, 8:30 am
either way it is what it is
looks like its coming along good , and the fab work looks good
5pointslow
5pointslow
Post  rodfarva November 26th 2013, 8:34 pm
A little more progress
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 A92861E7-D236-40DC-8512-ED3FF2BD59C4
Pedals mounted
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 9A465F47-EC25-45D2-B854-24776F561933
Steering column mounted
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 91862C7A-796A-4C2A-B3F1-BF9BD10FE15D
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 C5FE09B4-7818-4F5E-973D-8733C414C63F
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 B6CE6DC3-BF29-46BC-B808-064D1534F6BB
Window net mounted
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 6E5A2AFB-115B-46CF-A11A-06A92D8ECDA6
Working on the dash mounting. Please excuse the dust
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 AF473EF4-A885-4B6C-A293-1901996149B8
rodfarva
rodfarva
http://www.neverfastenoughracing.com
Post  psfracer November 26th 2013, 8:44 pm
You need to keep the [IMG] part of the tag and delete the [URL] part of the tag if you want the image to show. Nevermind, apparently its a problem on my end.
psfracer
psfracer
http://www.psfracer.com
Post  rodfarva November 27th 2013, 2:31 am
psfracer wrote:You need to keep the [IMG] part of the tag and delete the [URL] part of the tag if you want the image to show.  Nevermind, apparently its a problem on my end.
It is apparently something that photobucket has changed. In the past when I copied the IMG link from photobucket it didn't do that, but now it does. The images still display properly except on the mobile version of the this website.
rodfarva
rodfarva
Post  cletus66 November 27th 2013, 6:19 pm
It happens. Laughing
Looking forward to watching this all come together. Twisted Evil
Post  70FB November 28th 2013, 12:46 am
Nice work and keep on it. I'm getting ready to start cutting on my car..Because its mine.
70FB
70FB
Post  cletus66 November 28th 2013, 11:22 pm
70FB wrote:Nice work and keep on it. I'm getting ready to start cutting on my car..Because its mine.
I cut up my first car into a thousand pieces. It may never move under its own power again, but I still got it. Laughing
Post  rodfarva December 1st 2013, 3:56 am
Anybody have any thoughts on what this motor would be capable of NA with a good NA cam, tunnel ram style sheetmetal intake, and dual carbs? At the current CR of 11.7:1? At a higher CR? I'd probably still run alcohol so that I don't have to add a cooling system and change the fuel system later.
rodfarva
rodfarva
Post  BOSS 429 December 11th 2013, 8:50 am
rodfarva wrote:Anybody have any thoughts on what this motor would be capable of NA with a good NA cam, tunnel ram style sheetmetal intake, and dual carbs?  At the current CR of 11.7:1?  At a higher CR?  I'd probably still run alcohol so that I don't have to add a cooling system and change the fuel system later.
RUN GAS
Post  rodfarva December 20th 2013, 10:47 pm
I dropped the chassis off at the powder coater's the other day. I spent today prepping and painting the underside of the body shell so that it will be ready when the chassis returns from the powder coater.
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 3A8D7FFF-3F61-42C8-BD8C-7C36F07FA0FA
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 7B17C483-7970-40A8-919D-D8161A40F449
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 3333709A-611D-4EA1-B8A6-EA7AE8B6FB64
rodfarva
rodfarva
Post  BOSS 429 December 21st 2013, 2:09 am
looks like it coming along well
Post  TravisRice December 21st 2013, 9:37 am
Very nice . I am personally glad you cut up a Shelby, you will get more recognition just from that one small piece of the puzzle. Congrats.
Post  Mike R December 21st 2013, 9:22 pm
X2
Post  rodfarva December 27th 2013, 8:16 pm
I got a call today that the chassis powder coating is done. Unfortunately, I'm tied up with work and won't be able to pick it up until next Friday.
rodfarva
rodfarva
Post  rodfarva January 3rd 2014, 9:35 pm
Back from powder coating
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 C040E5D5-EE59-4D44-90A6-AF3E58A19E31
rodfarva
rodfarva
Post  Mike R January 3rd 2014, 9:49 pm
Bad ass cheers cheers cheers
Post  BOSS 429 January 3rd 2014, 10:10 pm
rodfarva wrote:Back from powder coating
LOOKS GOOD cheers
Post  rodfarva January 3rd 2014, 11:33 pm
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 A1114BA4-BFB2-4537-8A0D-E454B7922048
rodfarva
rodfarva
Post  rodfarva January 4th 2014, 5:45 am
This is the structural tree that ties the front clip together and supports it. It looks like a work of art. It's a shame that it will be mostly hidden.
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 7ED33108-091C-4341-9C7E-203E96FF0EAF
These are the frames that will support the Lexan side windows.
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 92429ADA-811B-4340-AB1F-EEA98AC0A758
The k-member. It started its life as a BMR piece.
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 1C52601E-C74E-456B-A736-C3CB8C276E92
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 6920DE8F-C378-4468-B3C2-B316F3BD076A
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 AB63C124-AE34-4AFB-98FC-6BB2FE12DFF3_1
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 0584815F-0BB7-4453-9EC1-C5208DA55C5A
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 4306B516-0CF1-40EE-A0A7-ACAC2BEBA79F
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 D6C3F803-6213-4C18-8DEC-7E8DCFEA60BD
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 145B70CA-A918-44AB-9D7B-1943AFDC34E3
Hemi Twin Turbo Outlaw 10.5 Shelby build - Page 4 269E86BF-6B32-45ED-B0F8-22A3E870BD6B
rodfarva
rodfarva
Post  61coon January 4th 2014, 9:30 am
Very nice! This thing will be unbelievable when you finish it!
61coon
61coon
Post  cletus66 January 4th 2014, 11:18 am
61coon wrote:Very nice! This thing will be unbelievable when you finish it!
X 2 !!!!  Shocked
