T-case speedo gear hole cover
Maybe someone here or possibly Lem can help me out with this.
I need the little plate that covers the speedometer gear hole in a BW t-case. My local junk yards dont have any late 80s-mid 90s 4wd trucks and my local Ford dealership is full of idiots. This would have to be from a truck that originally came with a VSS tone ring in the rear end.
Im using it on my 205 case but the bolt up is all the same.
Anyone have a junk case or one of these little plates laying around? Lem, any idea if you can get one new?
IcallhimGeorge- BBF CONTRIBUTOR
Re: T-case speedo gear hole cover
The transfer I had like that several years ago had a cup plug(freeze plug) drove in it. I have also used a regular drive insert with the cable cut off
lghting94- Posts : 762
I've used the rubber expanding freeze plugs
crittersf1- Posts : 521
didnt think about freeze plugs.
Thanks guys
Thanks guys
You still searching for a plug to fit your hole? Figured Paul would have taken care of that for ya.
kjett- Posts : 1169
Surprisingly (in a non-homosexual way) he did. Theres a cover on the case he busted in Rausch Creek.
I like the idea of the freeze plug better though.
Did you ever take some pics of the crossmember for me?
Not yet. I gotta go "un-wrap" it from the storage cucoon it's in so I can get the pic for you. If you can wait a few months, I'll have a clear shot when I cut the floor pan out.
kjett- Posts : 1169
You better get to work! I WILL be racing in March.
I'll be ready. Just spending much time learning at the machine shop and getting ready to do some "heart surgery"
kjett- Posts : 1169
» C6 speedo gear
» C4 speedo gear for 4.11 and 27 tall tire??
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
