bbf c-head ideas
badcoupe
bbf c-head ideas Empty bbf c-head ideas
Post  badcoupe December 21st 2011, 9:15 pm
ive been thinking real hard at 2013-2014 season taking some time off to build one bad ass C-headed deal
now ive thought about the turbo deal but to be honest its just out of my leauge - so what would you build ?
600 cubes
632 ?
or de stroke and turn the beast 9000 rpm ?
now be honest its a small tire car @ 3350 #,s
there are to many chevys building huge power and the fords are just not there -so im gonna take 2 years off and build a kiler piece -just not sure whats better ,i know ill need titanium valves and aluminum rods and big compression and cam
so tell me what you guys think cheers i would like 1200+ and 2 carbs are very doable if needed scratch
badcoupe
bbf c-head ideas Empty Re: bbf c-head ideas
Post  Lem Evans December 21st 2011, 9:18 pm
It's "doable" but, I see no reason to turn it 9,000 rpm.
Post  Lem Evans December 21st 2011, 9:23 pm
This is a 645" C460 engine with one 1450 QFX and the cast frpp 1x4 manifold.
bbf c-head ideas CCF05082011_00000Medium
Post  badcoupe December 21st 2011, 9:25 pm
I don't see a reason to have titanium Valves at 7200 rpm then is this correct
badcoupe
Post  Lem Evans December 21st 2011, 9:31 pm
I'd put in ti. intake valves for sure. A tunnell ram and 2 carbs will operate higher and make more power.
Post  richter69 December 21st 2011, 9:38 pm
Ti valves will make the welds on the oil pan leak...................... affraid
Post  bruno December 21st 2011, 9:47 pm
so you and Gerry Penn are building the same car or is this you with just a different screen name ?
http://WWW.CKRME.COM
Post  badcoupe December 21st 2011, 9:49 pm
Its me Bruno just decided against Turbo to much freaken money
badcoupe
Post  badcoupe December 21st 2011, 9:53 pm
What's a Max effort c head gonna flow
badcoupe
Post  rmcomprandy December 21st 2011, 10:40 pm
badcoupe wrote:What's a Max effort c head gonna flow
The question should be, "how much power can it make", not whether or not it flows the best.
Post  schmitty December 21st 2011, 11:35 pm
Flow is one small part of an engine equation and is important, but don't get hung up on flow numbers. Just look at what Blake did with his P head deal, the flow numbers don't add up to the hp it made. Have it built by someone who has the experience with these engines, because no matter how good you percieve yourself as a mechanic, unless you have experience on a daily basis with these engines, you are going to just be throwing money into the wind and not getting what you could. You would be surprised at how reasonable the labor is vs. the parts required for a build like this. Cool
Post  badcoupe December 22nd 2011, 7:24 am
i understand completely thats why lem will be involved with most of it and charlie of course if they wanna be ...
badcoupe
Post  dfree383 December 22nd 2011, 9:01 am
Biggest CID you Can afford, A205 Profilers and a 2x4 Induction......
Post  badcoupe December 22nd 2011, 9:17 am
I'm not selling my heads and building new headers again
badcoupe
Post  badcoupe December 22nd 2011, 9:18 am
What could a 600+ inch c headed deal make with 2x4 carbs
badcoupe
Post  Curt December 22nd 2011, 9:32 am
Mine made 1088 @ 7400/7500 rpm, with one single dyno QFX carb. Dyno'd on gas Mad
Jet Boat, Lem and Charlie build. farao king jocolor
My cam pirat
Some wacky adapter to fit my tunnel ram to one carb. Actually, the top of my intake is wacky and built for an Enderle and my T-2 set up. scratch
At the time, this was the highest horsepower C headed, 598 engine on Mike's dyno built by the above. If may have been de-throned since then. Suspect
I'll post the sheet for the first time. study
bbf c-head ideas Dynopage
bbf c-head ideas Empty C-460 combination
Post  Gary Blair December 22nd 2011, 10:53 am
Sometimes all you need to do is keep it simple. Keep the intake port small, just cartridge roll the runner, no increase in cross section. Focus on the bowl and valve job. Get after the cam, compression, and carb.
Gary Blair
Gary Blair
