sbf strike force heads
Ended up with a set of these heads, can't find much about them. Anybody have any info.
F2002360 sbf strike force Any help would be really appreciated.
sg86coupe- Posts : 184
Re: sbf strike force heads
Found this online. I have never heard of them before. Look okay for a budget type build. Don't know for sure but I would be willing to bet they are the same casting as pro-comp.
Strike Force Economical Small Block Ford aluminum heads are perfect for topping off your street rod project. Made in the USA and designed for street use they are available in 210cc intake runners and extra thick decks for strength, hardened intake and exhaust seats for unleaded fuel and come standard with magnesium bronze valve guides for extra long life.
Assemblies have 2.02 x 1.60 stainless valves, 3/8 rocker studs, 5/16 pushrod guide plates, 7 deg chrome moly steel retainers & valve locks and premium viton valve seals. Hydraulic flat tappet single springs are 1.250 diameter and hydraulic roller or solid flat tappet dual springs are 1.460 diameter.
Strike Force heads are ideal for 302, 5.0L, 351W & 5.7L cid street engines up to 550 HP.
Made in the USA
60cc chambers
Extra Thick decks
Hardened valve seats
1.250 OD single spring 110lb at 1.700, .510 in lift hyd cams #3000
1.460 OD dual springs 135lb at 1.800, .600 in lift hyd roller and solid flat tappet cams #3400
Part Number Description Port Vol. Cham. Vol. Int/Exh Valves Spring Dia. Cam Price In stock Purchase
SF210 Bare, pr 210 60 2.02/1.60 N/A N/A $679.50 Yes
SF210-K30 Assem, pr 210 60 2.02/1.60 1.250S Hydraulic $829.50 Yes
SF210-K34 Assem, pr 210 60 2.02/1.60 1.460D Hyd Roller $899.50 Yes
SF210-K34 Assem, pr 210 60 2.02/1.60 1.460D Solid, flat $899.50 Yes
Made in the USA
60cc chambers
Extra Thick decks
whatbumper- Posts : 3024
I was told these heads are from the Pro castings that were in New Zeland. I've seen Pro Comp's version of a Victor jr, and these heads look nothing like them.
Then check RHS's website. Comp cams bought pro topline out and sell them in their rhs line.
» john force
» A little venting on the HP tv deal
» Courtney Force just......
» Went to Indy this week
» Ashley Force sitting on the side line?
