NOS cam suggestion
Tennessee Bullitt
NOS cam suggestion Empty NOS cam suggestion
Post  Tennessee Bullitt December 28th 2011, 10:17 pm
Ok I wanna throw out some cams here and see what you guys think would be a better cam for a 400 shot on a progressive setup.....
cam 1 cam 2 cam 3
Dur@.020 305 / 317 Dur@.020 301 / 314 Dur@.020 306 / 318
Dur@.050 272 / 284 Dur@.050 271 / 283 Dur@.050 275 / 287
Dur@.200 189 / 201 Dur@.200 191 / 204 Dur@.200 197 / 206
Lift .746 / .746 Lift .742 / .738 Lift .738 / .738
112 LSA 112 LSA 112 LSA
cam 4
Dur@.020 303 / 321
Dur@.050 273 / 285
Dur@.200 193 / 201
Lift .742 / .774
112 LSA
Steve if you read this I would like to e-mail you about what I am doing. It has been a pain to try and get time to talk to you.
I figure a 112 LSA would be a good starting point weather it needs more or less. Any ideas? I am probing to see how far off I am on this.
Tennessee Bullitt
Tennessee Bullitt
NOS cam suggestion Empty Re: NOS cam suggestion
Post  richter69 December 29th 2011, 6:28 pm
whats the rest of the specs on the motor, car, etc?
Post  Tennessee Bullitt December 29th 2011, 9:32 pm
You gonna make me give out my G14 classified, top seceret stuff? Very Happy I was curious how the lobes and basic setup would work with a 400 of N2O.
Tennessee Bullitt
Tennessee Bullitt
Post  richter69 December 29th 2011, 9:37 pm
might work good for a given combo and not so good for another...............
Post  Tennessee Bullitt December 29th 2011, 9:54 pm
OK here it is....
554 cu in
trick flow a460 heads..... flow #'s as follow.
2.35 intake / 1.88 exhaust
in / ex
.100 80 72
.200 170 134
.300 251 182
.400 325 227
.500 389 271
.600 430 312
.700 455 345
.800 463 364
13.0 compression
flat top pistons
1195 BG king demond R/S carb..... if I can find the 1295 sleeves thats what I will go with.
6.8 rods
4.3 crank
4.530 bore
thinking 2 3/8 headders or mabe bigger. I am gonna custom build my own
turbo 400 trans
3.55 gears
max rpm's up to 7500.
stall I still need to figure out cam but was looking at a 3500 on motor.
Tennessee Bullitt
Tennessee Bullitt
Post  studly December 30th 2011, 3:13 pm
I dont think any of those are enoph cam for 400 worth of N20, i will look at home i still have a custom for an A headed nitrous motor and will post the specs for it.
studly
studly
Post  Tennessee Bullitt December 30th 2011, 7:06 pm
cool thanks.
Tennessee Bullitt
Tennessee Bullitt
Post  Lem Evans December 30th 2011, 7:34 pm
Yep...more duration, more lift and a wider LSA.
Post  Tennessee Bullitt December 30th 2011, 9:09 pm
I just want to throw out a few things here. I don't want to spin it to the moon to make any power without the juice like 8,500 rpms or more. I know it will not run N/A like a N/A cam. Oliver rods, scat 4340 crank, and diamond pistons will be good to 8,000+ rpms, but like we built my 521 SCJ, Lem it worked awsome for me, I know you like it as well. It is not using NOS every pass, but have the capibility when a grudge race does present itself.
Tennessee Bullitt
Tennessee Bullitt
Post  richter69 December 30th 2011, 10:20 pm
destroke it and spin it 9000 rpm.............. Wink
Post  res0rli9 December 31st 2011, 2:23 am
Hell just take to 12,000 itll take and mo powwer to.
Post  Lem Evans December 31st 2011, 12:19 pm
Even N.A. you'll need more cam than you have listed.
Post  Tennessee Bullitt December 31st 2011, 6:54 pm
Ok so I am way off on duration, what should I be looking at? 276/288 range and what about the LSA? 114? My next list of cam profiles are going up to a .800 + or - a little.
Tennessee Bullitt
Tennessee Bullitt
Post  res0rli9 December 31st 2011, 11:57 pm
Just let Lem spec. you a cam and qiut gessing scratch
Post  Tennessee Bullitt January 1st 2012, 10:04 am
It's not about guessing, I am trying to learn about different motors I build. I am going off the last one I did and a basic desktop dyno to see the what, why, and learn the results. Hey Lem I hope they don't kick me out of the seminar this month for asking to many questions. Very Happy
Tennessee Bullitt
Tennessee Bullitt
Post  studly January 1st 2012, 12:53 pm
285- 290 @50 intake 300 -312 @50 exhaust 114 lobe separation 114 center-line 800 plus lift intake and 780 -800 plus exhaust probably install at 112.
But i would probably call Lem and tell him to get to work and have my cam here this coming week no excuses Laughing Laughing
studly
studly
Post  bruno January 2nd 2012, 3:17 pm
studly wrote:285- 290 @50 intake 300 -312 @50 exhaust 114 lobe separation 114 center-line 800 plus lift intake and 780 -800 plus exhaust probably install at 112.
ive got a baby cam compared to those #'s
http://WWW.CKRME.COM
Post  studly January 7th 2012, 10:17 pm
I just put up 2 cams for sale, one of them should work really good with 400 hit of n20 with a460 heads
studly
studly
