ring gap
bluecoupe
ring gap
i have a 545 with probe pistons in with a 300 shot on it what ring gap would be normal for something like this. the rings will be hellfire
bluecoupe- Posts : 26
Re: ring gap
Use whatever the ring mfr recommends.
jbozzelle- Posts : 3705
Re: ring gap
http://www.aa1car.com/library/ring_info_speedpro.pdf
Re: ring gap
bluecoupe wrote:i have a 545 with probe pistons in with a 300 shot on it what ring gap would be normal for something like this. the rings will be hellfire
With 2618 Forged aluminum material and NITROUS you're looking at about .007" per inch of bore for the top ring.
The second ring is typical at .005" per inch of bore; (the same as without nitrous).
The extra heat of using nitrous will make the top ring grow more and both will be about the same end-gap when running.
Re: ring gap
rmcomprandy wrote:bluecoupe wrote:i have a 545 with probe pistons in with a 300 shot on it what ring gap would be normal for something like this. the rings will be hellfire
That would put my gap at .031 for my engine................. Guess I best back off that 175 shot I was thinkin bout putting on it.
Re: ring gap
why? chicken?IDT-572 wrote:rmcomprandy wrote:bluecoupe wrote:i have a 545 with probe pistons in with a 300 shot on it what ring gap would be normal for something like this. the rings will be hellfire
Re: ring gap
cool40 wrote:why? chicken?IDT-572 wrote:rmcomprandy wrote:bluecoupe wrote:i have a 545 with probe pistons in with a 300 shot on it what ring gap would be normal for something like this. the rings will be hellfire
Re: ring gap
I'm no where close to .031 lol......but then again I didn't gap them with ever the idea it would have a whiff of spray on it either.............next time around they will be wider I promise.
Re: ring gap
richter69 wrote:I'm no where close to .031 lol......but then again I didn't gap them with ever the idea it would have a whiff of spray on it either.............next time around they will be wider I promise.
I may spray anyway....................
Re: ring gap
250 at the least!IDT-572 wrote:richter69 wrote:I'm no where close to .031 lol......but then again I didn't gap them with ever the idea it would have a whiff of spray on it either.............next time around they will be wider I promise.
Re: ring gap
That would put my gap at .031 for my engine................. Guess I best back off that 175 shot I was thinkin' bout putting on it.
OR, run it on the RICH side to keep the excessive heat down, LOL. Power increase suffers a bit though.
» piston ring choice and preferred ring seat/breakin time ?
» Do they make a ductile Iron ring 5/64 X 4.39 bore or whats a good ring?
» ring gap for n0s
» Filing rings
» Ring Gap
» ring gap for n0s
» Filing rings
» Ring Gap
