heavy flywheels
heavy flywheels
what do you guys think about using an old heavy jw flexplate with a glide. did these work better than a light one ?, i see companys making aluminum ones now.
10SHOTS- Posts : 587
Re: heavy flywheels
old heavy JW wheel works in my junk just fine.........
Re: heavy flywheels
Just asking , but do you think you would pick up any with a lighter one ? or slow up somerichter69 wrote:old heavy JW wheel works in my junk just fine.........
Re: heavy flywheels
I am pretty sure that the aluminum wheels are about the same weight as a steel one....due to their thickness.
The biggest performance advantage that I can see is longevity, since the aluminum ones have a bolt on ring gear. The welds on the steel ones like a JW seems to be the failure point at higher HP, heavy car applications.
Here is a link about the aluminum CSR wheel that I run. It is doing a fine job.
https://www.429-460.com/t10836-new-csr-flexplate
I have the weights all written down....but do not have the info with me right now.
Keith
Keith
Re: heavy flywheels
10SHOTS wrote:Just asking , but do you think you would pick up any with a lighter one ? or slow up somerichter69 wrote:old heavy JW wheel works in my junk just fine.........
I wouldn't trust one that was lighter/weaker. As Keith noted some have had issues with the JW wheel, knock on wood mines been fine, and I bought it used lol. I will be making a change to a better one some day, I wouldn't say its lighter though.
6 pads vs 3 is a good thing.................
» Protection from exploding flywheels and flexplates
» Mcleod flywheels
» Question about flywheels
» power glide flywheels
» Internal and external balance flywheels
» Mcleod flywheels
