BBF and glide combination
BBF and glide combination Empty BBF and glide combination
Post  Art January 14th 2012, 1:49 pm
I need to sell the below listed motor and transmission. I have the opportunity to purchase another set up. This motor and transmission have zero runs. It has all new bearings, it was just honed, decked, etc. Just spent $2500 on machine work, etc. The rods and pistons have about 25 1/8 mile passes.
It as an A460 block.
4.5” stroke Callies crank, forged
Diamond gas ported, coated pistons, skirts and tops. (2 extra pistons) Rings are Total Seal Tool Steel rings. Rings were $500 for 10 sets.
C-460 heads fully ported by Charlie Evans and Mike Curcio of MCRP, heads were just redone and have new Manley springs, and fresh valve job.
C-460 intake port matched to heads
T&D rockers, lunati lifters
Titanium Intake valves and steel exhaust
MSD crank trigger and distributor
Jeff Johnston Wet sump pan
Stock car products external oil pump
CSR water pump
Moroso vacuum pump
Skinny Kid Motor and Mid plate
New, still to receive 1400 cfm Pro Systems nitrous carburetor for this engine combination
Danny Bee Belt drive, new belt, Torrington bearins, and seals
Crane solid roller cam for nitrous
Manton Push rods-new
NX Pro Shark Fogger-comes with 4 10lb nitrous bottles
Edelbrock widow maker plate
Custom step headers for fox body, with collectors and dynomax mufflers
All ARP hardware, mains, heads, and intake (new)
ATI super dampner, aluminum shell, nib
Aluminum race radiator
Of course all is zero balanced
Transmission is fresh rebuild:
JW case and tail shaft-tranny is fully rollerized
8 clutch drum
Billet dual ring servo
1.69 BTE straight cut gears with vasco input shaft
Bradco nitrous converter being redone at this time
TCI aluminum race pump
Hipster aluminum valve body
B&M quarter stick shifter, still in box
Drive shaft for fox body
Particulars on heads and cam shaft given to serious inquiries only. I have a limited amount of time, so please only contact if you are serious. I can provide pictures of whatever you would like. The motor is not fully assembled. The short block has been assembled. We can finish installing rest of motor parts or leave as is
Complete package $25,000, can help with delivery or will pay half the shipping
Contact with any questions
Art Payne
812-989-4903
ArtHPayne@aol.com
Art
