BIG SHOT PLATE with 300 shot
yellowhorse7
Barney
10SHOTS
Page 1 of 2
Page 1 of 2 • 1, 2
how cold of a plug should i use , moving up to 300 shot this weekend paper work says use #11s but i foul 10s all ready warming the motor up, . what plugs are you guys using ?
big shot plate, 104n-93g jets 5.25 pnds fuel pressure 19 degrees total timing.34 engine -15 pulled out
soleniod has a.109 orfice using a #4 line also.
10SHOTS- Posts : 587
Re: BIG SHOT PLATE with 300 shot
I've used 10s on a similar tune. Just be a tad conservatine with your timing.
Id want more jet spread, iirc you were close to maxing out the noid as it was, if thats the case youll want more spread the higher you go.
I always warn the car up on a set of old plugs, if Im trying to read plugs when trying a diff tune Ill stick a fresh set in and drag it to the lanes...... start it and do a burnout.... then make the pass and click it at the stripe. I run a ngk 10
Me and Barney used 10's when we used the "no jet" tune up
Hurt alotta feelings that day....
yellowhorse7- Posts : 1382
does anyone think this is a bad combination
big shot plate, 104n-93g jets 5.25 pnds fuel pressure 18 degrees total timing.34 engine -16 pulled out
soleniod has a.109 orfice using a #4 line also. , 280-292 @.050 112 lobe sep. cam with 14.1 compression,562 CID sonoco max nos 116 fuel #11 ngk plugs
im a poor boy ,i dont need to F this motor up . is there any thing i need to change with this nos tune up.
big race this weekend
Id maybe put a little more spread (not much) and take 1-2 more of timing out......and read the plugs from there.
richter69 wrote:Id maybe put a little more spread (not much) and take 1-2 more of timing out......and read the plugs from there.
X2. Go down 2 fuel sizes and take 2 degrees MORE timing OUT. I'd bet it wants 5.5lb FP...
yellowhorse7 wrote:richter69 wrote:Id maybe put a little more spread (not much) and take 1-2 more of timing out......and read the plugs from there.
I guess I'm looking at this too simple but why would he want to drop jet sizes and then increase fuel pressure?
whatbumper- Posts : 3024
whatbumper wrote:yellowhorse7 wrote:richter69 wrote:Id maybe put a little more spread (not much) and take 1-2 more of timing out......and read the plugs from there.
Well he could go down 1 size and leave FP alone but IMO thats a big swing. Smaller (safer) swing my way IMO
I just don't see a difference but I flow plates by fuel weight per second and do the math. May not be perfect but tends to work.
whatbumper wrote:I just don't see a difference but I flow plates by fuel weight per second and do the math. May not be perfect but tends to work.
Seems like there are a few ways to skin the kitty. I also noticed that Q16 was alot more sensative to little stuff on my deal. He's not using Q but I figured I'd add my thoughts...
WHAT DO THE PLUGS LOOK LIKE ????
bruno wrote: WHAT DO THE PLUGS LOOK LIKE ????
You just worry about your baby tune ups.....let the grown folks speak here playa
I don't think he's made a pass yet
yellowhorse7 wrote:bruno wrote: WHAT DO THE PLUGS LOOK LIKE ????
thats fine and dandy but he needs to put his faith in 1 person and start with a baseline and go from there ...to many cooks in this kitchen will fo sure burn the filet up !!!
bruno wrote:yellowhorse7 wrote:bruno wrote: WHAT DO THE PLUGS LOOK LIKE ????
Steve should be the final answer then....
yellowhorse7 wrote:bruno wrote:yellowhorse7 wrote:bruno wrote: WHAT DO THE PLUGS LOOK LIKE ????
whomever is going too get involved in the tunme should be the only one ...just my .02 .... you , steve, me .......... etc opinions are fine but once we start spitiing ot tunes ........... boom !!!! ...have a great weekend
he sent me a pm a few days ago, it'll be a HeRo or a ZeRo.........
richter69 wrote:he sent me a pm a few days ago, it'll be a HeRo or a ZeRo.........
Good....I have NO idea what I'm doing anyway
the whole weekend was a zero. they preped the track for radial tire cars,every one with slicks was fighting to get down the track.
that makes no sense, evertime they prep ours like that I bend frontend parts........
10SHOTS wrote:how cold of a plug should i use , moving up to 300 shot this weekend paper work says use #11s but i foul 10s all ready warming the motor up, . what plugs are you guys using ?
I was out of town and missed a few day and just saw this.. That tune is likely VERY rich just based on the info posted. Also based on what you have said it sound like you have a carb issue that needs to be cured before any nitrous tuning is done properly ?? If it kills the plugs on a warm up I would look at the over rich idle conditions and work from there..
You are near maxed out on your solenoid, you have a smaller line (-4), AND POSSIBLY THE PLATE IS CLOSED TO MAXED DEPENDING ON WHAT YOUR WORKING WITH ???
If not hurting an engine is key to your program I would be careful what you do to the set up. Have you sprayed it before or are you calling this a starting point ?? Sometimes if unsure of your tunes, starting smaller is a lot safer. Not taking anything away from anyone that tries to help, but many forget when guys are firing off tunes with limited info on the set up and combo, they have really nothing to lose if it dosen't work out for the end user.. Hope this helps.. SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
This is where having a system blueprinted and jetting mapped is worth its weight in gold..... moreso with big tunes.
richter69 wrote:that makes no sense, evertime they prep ours like that I bend frontend parts........
i dunno what was going on , they was draging this contraption behind a tractor that had 2 big wide slicks on it that turned backwards and said they was using a different compound. my brothers car had the same problem as i did. he had a set of x275 pro radials on wheels in the trailer , put those on and then couldnt keep it off the bumper, he kept trying to get me to try them on my car but by then i was agravated and didnt worry with it
steve i been running this setup
big shot plate, rpm soleniods nos jet map for 275 95n jet 85 fuel with 5.25 fuel psi, and a #4 line and have not hurt the engine (yet), i got the carb issue fixed up now, I was just wanting to shoot around 325 and not damage the motor, if i need to upgrade parts tell me what to buy and i will call you and get them.
Page 1 of 2 • 1, 2
» Sunday History Class
» Nitrous problems ,car will not pick up
» NOS BIG SHOT PLATE
» NOS 200/250 Shot.
» Getting The Most from 1 Shot?
» NOS 200/250 Shot.
Page 1 of 2
