BIGGER valve for SCJ Heads?
Im using a set of SCJ Kaase heads on a 572, what size valves should I squeeze into these, im gunna have these ported also.Thanks
stanggt- Posts : 494
Re: BIGGER valve for SCJ Heads?
stanggt wrote:Im using a set of SCJ Kaase heads on a 572, what size valves should I squeeze into these, im gunna have these ported also.Thanks
Simple enough question,,,, but imo the proper procedure would be to find a good head porter who is familiar with porting and flow testing the SCJ heads and then ask him that question and follow his advice.
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
thats good advice, was just on here and was thinking out loud for a moment and my fingers hit the key board.
![Laughing](https://2img.net/i/fa/i/smiles/icon_lol.gif)
probly hit up Randy, he is only a couple hours away from me I think.
The intake seats in an SCJ head are just under 2.300" in diameter, (58mm plus the press), so, a cut down 2.300" valve to 2.280" with a thick margin works OK if the engine is not overheated and kept out of detonation. Otherwise a 2.250" is the largest if those things might happen.
thanks Randy, we'll talk soon. I know I need abigger better set of heads for this big cubes but thats what I have for now so I will have to do what I can to these unless I can move them to someone. I just remember seeing someone getting some good flow from these heads just dont remember where i read about it.
stanggt wrote:thanks Randy, we'll talk soon. I know I need abigger better set of heads for this big cubes but thats what I have for now so I will have to do what I can to these unless I can move them to someone. I just remember seeing someone getting some good flow from these heads just dont remember where i read about it.
Air flow wise - a well ported aluminum SCJ head is about like an "out of the box" P-51 would flow.
that would be greatrmcomprandy wrote:stanggt wrote:thanks Randy, we'll talk soon. I know I need abigger better set of heads for this big cubes but thats what I have for now so I will have to do what I can to these unless I can move them to someone. I just remember seeing someone getting some good flow from these heads just dont remember where i read about it.
![Very Happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png)
chris
» Anyone know if you can put a bigger seat in the TFS 290 heads?
» Bigger carb or bigger headers opinions needed
» valve covers for P51 heads...
» Valve cover help for the scj heads
» Valve Springs A-460 heads
