D0VE Block
+8
Baitshop
nuclearcobra
GT300TD
DavidNC23
12 posters
D0VE Block
I have looked around the internet and cant seem to find a list of Year/Make/Model vehicle that would have had the thick webbed D0VE block. I am getting closer to starting my build and want to know what vehicles I should be looking for? Can anybody help?
DavidNC23- Posts : 15
Re: D0VE Block
1970= D0VE
Re: D0VE Block
They are out there but,finding a stock bore one is getting tough these days.
Re: D0VE Block
Got one on a stand in my garage with the 429 pistons and crank still in. Darn near gave the virgin D0VE-C heads and bolts away ($125) to a mechanic friend, hope he remembers that when he tunes my 466 this summer.
GT300TD- BBF CONTRIBUTOR
Re: D0VE Block
Mine came from a 70 lincoln
nuclearcobra- BBF CONTRIBUTOR
Re: D0VE Block
There is a fellow in Minnesota that has one for $400. I think he has posted it on one of the forums. If not, it's on craigslist somewhere. I can dig it up if you're in that neighborhood.
-Jared
-Jared
Baitshop- Posts : 58
Re: D0VE Block
IN SEPT 74 MY STEPDAD bought a new 75 ltd,in 1988 i took the starter off it was a dove block, now its in a guys 56 f100 truck, ive found them in 70 cars to 78 linkcons, just got to look
BOSS 429- Posts : 2372
Re: D0VE Block
From the info I did find on the net, I gathered that the D0VE blocks where used from 1970-1973. So from what you guys are saying, anytime I happen to find a 1970 to 1973 FMC big block vehicle, as long as it has the factory motor, it will have the D0VE block. Is that a correct assumption? I have also heard that the stock cast crank and rods in those where super strong and I have heard people talk about the D0VE-C heads. My motor will go in a dragster. I want to make about 650HP and go 5.00's in the 1/8th. Will the factory crank and rods be fine? Will the D0VE-c heads (with some work) be fine? Anything I can use and not have to buy aftermarket would save me a bunch of money. This is a starter bracket motor that I dont want to have to worry about leaning on or running over the crank.
Re: D0VE Block
well kinda, on the other side of the fence we bought a 1 owner 70 clycone c code, vin on the block all org,, lol it had a c9ve block, it was a dooe-r cj engine, so as i said you have to look
Re: D0VE Block
DavidNC23 wrote:From the info I did find on the net, I gathered that the D0VE blocks where used from 1970-1973. So from what you guys are saying, anytime I happen to find a 1970 to 1973 FMC big block vehicle, as long as it has the factory motor, it will have the D0VE block. Is that a correct assumption? I have also heard that the stock cast crank and rods in those where super strong and I have heard people talk about the D0VE-C heads. My motor will go in a dragster. I want to make about 650HP and go 5.00's in the 1/8th. Will the factory crank and rods be fine? Will the D0VE-c heads (with some work) be fine? Anything I can use and not have to buy aftermarket would save me a bunch of money. This is a starter bracket motor that I dont want to have to worry about leaning on or running over the crank.
The stock rods will depend on how hard you going to turn the engine at what rpm the stock crank will handle it the dove-c heads might get you there but you will have as much in them as you could pay for a set of the SCJ aluminum heads that Lem sales. I have about 2/3 the cost of the scj in my dove-c heads and still have the factory size valves in them I am making around 570 hp.
Re: D0VE Block
So just go with the Alum SCJ heads, your comment about "depends on how hard I am going to turn the engine" sends up a red flag for me. I dont want to have to worry about how hard I turn the engine. Dont get me wrong, I wont be spinning this thing to the moon, however, if there is a point at the HP levels I am talking about, that I would have to worry about the rods, I would rather be safe than sorry. The stock cast crank will completely handle the HP I want to produce, correct?
Re: D0VE Block
factory cast crank from all i have read will handle as much as the block will handle,some say the rods will be ok up to 7000 rpm some say keep it below 6500.I am running the late model truck rod that are supposed to be about the strongest factory rod from what i have read about the factory rods i have my rev limit set at 6500 rpm.But now I am uping my hp i will be going with h beam rods with dome piston to get as much compression as i can.
Oh good luck finding a dove block
Re: D0VE Block
new rods are good insurance,IMO.the block and crank will be good to go. some D1VE blocks are thick like the D0VE.
Re: D0VE Block
I believe the doves have a slightly shorter deck height then the dive's.
mudtrucker- Posts : 160
block
Last time I talked to Paul Kane a week ago, he had several DOVE blocks in stock, you might get ahold of him.
blown473- Posts : 376
Re: D0VE Block
I have two dove blocks in the shed and one more in the garage. Where are you located?
fe50stang- Posts : 132
Re: D0VE Block
DavidNC23 wrote:I have looked around the internet and cant seem to find a list of Year/Make/Model vehicle that would have had the thick webbed D0VE block. I am getting closer to starting my build and want to know what vehicles I should be looking for? Can anybody help?
ALL original 429 SCJ powered vehicles had the 4 bolt main block. It was in a lot of other vehicles sporadically.
Re: D0VE Block
fe50stang wrote:I have two dove blocks in the shed and one more in the garage. Where are you located?
Far from you....Charlotte NC
» D0VE-A block
» D0VE-A Block
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» D0VE-A Block ***SOLD***
» D0VE-A Block HP & 1/4 Mile records
» D0VE-A Block
