D0VE-A block
dirt_worker
medbali76
D0VE-A block Empty D0VE-A block
Post  medbali76 June 25th 2010, 4:49 pm
I bought a 460(?) today. I am not familiar with these engines so I have a few questions.
After a quick check I found a few casting numbers which are really strange.
This engine came out of a 7x motorhome (according to the seller)
The block casting number is D0VE-A and I found a small 460 casting on the lower front area.
The heads have different numbers. One of them is D0VE-C and the other is D3VE-A2A
The seller said that they have measured the ports, valves, the chambers and they are same. Is that possible? If I remove the valvecover can I find things ( for example valvetrain) which are identify the '73 and later heads and '68-72 heads?
The intake manifold castings start with D9 and the timing cover with D2 letters.
Any idea? scratch
medbali76
D0VE-A block Empty Re: D0VE-A block
Post  dfree383 June 25th 2010, 5:00 pm
D3 and D0 header do not interchange. The D3 heads have much larger chambers.
Post  medbali76 June 25th 2010, 5:08 pm
dfree383 wrote:D3 and D0 header do not interchange. The D3 heads have much larger chambers.
So the best way would be to remove the heads and double check them? I have just checked the exhaust side because there are no exhaust manifolds on it.
From the exhaust side they are exactly the same.
medbali76
Post  dfree383 June 25th 2010, 5:13 pm
You should use either on casting or the other. Compression will vary about 1.5 points from the d3 to the D0. And if the valve trains are factory, each will have different type rockers.
Post  medbali76 June 25th 2010, 5:37 pm
dfree383 wrote:You should use either on casting or the other. Compression will vary about 1.5 points from the d3 to the D0. And if the valve trains are factory, each will have different type rockers.
I will remove the valvecover tomorrow. What if they have the same valvetrain? I am pretty sure of that seller is not that stupid to use different heads. He wanted to put this engine into his '71 mach1. Unfortunatelly he got financial problems, that is why he sold it.
Is it possible that only the casting wrong,and they are really same? As I know there was a big chaos around that era with casting numbers.
medbali76
Post  dfree383 June 25th 2010, 6:06 pm
No its not possible if one is a D3VE (92cc) and the other is a DOVE (76cc)
unless your reading the number wrong.
Post  medbali76 December 9th 2011, 10:08 am
I decided to take apart this engine yesterday and I really surprised of what I found inside.
4 bolt mains... what the h...??? what car did this engine come from? Not from a motorhome as the seller told me for sure.
I collected all the casting numbers I found. Here they are:
Block: D0VE-A 4 bolt mains, CJ 3 or CJ 8 casting in the oil valley above the date code, date code is 0L18, scratch mark on the back ( same as on the 428CJ block) looks like "t" or "c", stamped number on the back 1A185790, 460 casting mark on the front and on the back
Main caps: starts with C9AE (for example main cap #3: C9AE / 6330 B )
Rods: D6VE-AA , rod caps: C9AE-B
Piston: 50 460
Crankshaft: 3YA
Can somebody help me to identify this engine/block? I am wondering maybe this is a 429 CJ/SCJ 4 bolt Block.
Thank you.
Balazs
medbali76
Post  dfree383 December 9th 2011, 10:11 am
Sounds like you ended up with a SCJ or Possibly CJ or PI 4 bolt block.
Post some pictures up we'll give you a 100% ID on it.
Post  medbali76 December 9th 2011, 10:54 am
dfree383 wrote:Sounds like you ended up with a SCJ or Possibly CJ or PI 4 bolt block.
Here are the pics:
https://picasaweb.google.com/112656570976060097191/385SeriesBigblock
medbali76
Post  dfree383 December 9th 2011, 11:20 am
Yep thats a 429 SCJ / CJ / PI 4 bolt block with a later 460 rotating assembly in it.
Post  medbali76 December 9th 2011, 11:27 am
dfree383 wrote:Yep thats a 429 SCJ / CJ / PI 4 bolt block with a later 460 rotating assembly in it.
Thanks. All of these engines use the same block?
Does this stamped number tell anything?
1A185790
medbali76
Post  dfree383 December 9th 2011, 11:38 am
SCJ's where supposed to be all 4 bolt's, CJ's a few and Police Intercepters, Some to most.
Thats the VIN nunber of the car it came from, should be a Torino or Merc
Post  medbali76 December 9th 2011, 12:02 pm
dfree383 wrote:SCJ's where supposed to be all 4 bolt's, CJ's a few and Police Intercepters, Some to most.
Thanks for your help Wink
medbali76
Post  dirt_worker December 9th 2011, 12:12 pm
Nice.....
What about the heads, what is your findings there?
Btw..how much did you pay?
dirt_worker
dirt_worker
Post  medbali76 December 9th 2011, 12:14 pm
One more question please. What about those 460 marks? Is that normal on a 429 CJ?
medbali76
Post  medbali76 December 9th 2011, 12:31 pm
dirt_worker wrote:Nice.....
I bought this engine with different heads. One of them was D0VE-C and the other was D3VE-A2A.
The price does not tell you anything. The V8 engines have high price tag here in Hungary because you can not find any V8 engines in the junk or salvage yards. Shipping the engines overseas are horrible so they are more more expensive here than in the USA.
Btw.. I payed around $1700 for the complete rebuilt engine with a good C6 tranny. It is still standard bore looks like it got only new gaskets and seals.
medbali76
Post  medbali76 December 9th 2011, 12:37 pm
Were the SCJ blocks only solid lifters or both?
medbali76
Post  dfree383 December 9th 2011, 12:40 pm
SCJ's came with solid, CJ's and PI's had Hydraulics. The lifters work in either block, they are not like early FE's.
The one you have has odviously been redone as some piont and has a later 460 truck rotating assy and I'd guess a hydraulic cam.
Post  dfree383 December 9th 2011, 12:41 pm
medbali76 wrote:One more question please. What about those 460 marks? Is that normal on a 429 CJ?
Yes, they can be on them too. no real rime or reasoning behind the marks sometimes.
Post  medbali76 December 9th 2011, 12:59 pm
dfree383 wrote:SCJ's came with solid, CJ's and PI's had Hydraulics. The lifters work in either block, they are not like early FE's.
Yes, it has a hydraulic cam.
So,you say there are no any visible difference between them? There is no way to identify a solid or hydraulic block?
medbali76
Post  dfree383 December 9th 2011, 1:02 pm
No difference in the blocks.
Post  medbali76 December 9th 2011, 1:15 pm
Thanks, I got answers for all my questions Very Happy
medbali76
Post  medbali76 December 9th 2011, 6:26 pm
Any idea on the value of this block?
Since I do not need this engine probably I will try to sell it.
medbali76
Post  dfree383 December 9th 2011, 6:56 pm
Tough to say where your at. But in in the US $750-$1000ish depending on who want it and why. Numbers / restoration guys will spend more them than racers.
Post  medbali76 December 9th 2011, 7:05 pm
dfree383 wrote:Tough to say where your at. But in in the US $750-$1000ish depending on who want it and why. Numbers / restoration guys will spend more them than racers.
Thanks, I do not think that It will have any interest here in Europe but have to try otherwise it will stay in my garage forever. Crying or Very sad
medbali76
