Solid Roller ?
JR Performance Motorsport
Solid Roller ?
For an endurance style BBF 513 ci with a cam of around .750 lift, what lifters do you guys recommend?
Thank you
JIm
Thank you
JIm
Re: Solid Roller ?
I'd say Comp Cams # 836 will do fine. You're not talking about much lift, and for "endurance" I am assuming that your springs pressures will not be real radical.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Re: Solid Roller ?
JR Performance Motorsport wrote:For an endurance style BBF 513 ci with a cam of around .750 lift, what lifters do you guys recommend?
Thank you
JIm
Personally, for milder type engines I use the Lunati #72412-16 which are very similar to the Crane lifters used in the FRPP crate 514's. As a longevity exercise, I put those lifters in a 1,200 horsepower, supercharged, 528, drag boat engine because it gets refreshed every year and I could keep track of the wear progression. After 3 years, they got replaced.
The Comp Cams will also work fine.
EDIT: if it is an engine that has a lot of idling time then I would use a lifter with positive oil pressure to the axle.
Last edited by rmcomprandy on February 12th 2012, 11:36 am; edited 1 time in total
Re: Solid Roller ?
Morel's are nice too.
Re: Solid Roller ?
rmcomprandy wrote:JR Performance Motorsport wrote:For an endurance style BBF 513 ci with a cam of around .750 lift, what lifters do you guys recommend?
Thank you
JIm
I believe I have a set of Crane lifters that I got from someone here. They have very little use or show very little wear. I have another set I also got here that I have no idea what make they are, but different than the others. Does anyone have a picture of there lifter that they will post ?
Thank you
Jim
Re: Solid Roller ?
Jim,
I think you bought a used set of Comp Solid Roller lifters off me a few years back.
Later Mark.
Later Mark.
Mark Miller- Posts : 1946
Re: Solid Roller ?
Mark Miller wrote:Jim,
Later Mark.
Cool those are what they are. I have been running them ever since. I just forgot where/who I got them from. So now what is what.
Thank you
Jim
Re: Solid Roller ?
How long have you been running them in the boat? since you bought them off me?Glad they have held up for you.
Later Mark.
Later Mark.
Re: Solid Roller ?
I have about 3 actual race hours on them. They are going in an engine,513 iron head, again for the race of the season. My other Crane lifters are going in my 513 with Blue Thunders.Mark Miller wrote:How long have you been running them in the boat? since you bought them off me?Glad they have held up for you.
Later Mark.
Will Comp go through and freshen them up ?
Re: Solid Roller ?
I'm pretty sure Charlie Evans told me Comp can rebuild them for you.
Later Mark.
Later Mark.
Re: Solid Roller ?
Yes Comp will rebuild them. I'm sending in a set tomorrow.
Ace
Ace
powerstrokeace- Posts : 1496
Re: Solid Roller ?
JR Performance Motorsport wrote:Mark Miller wrote:How long have you been running them in the boat? since you bought them off me?Glad they have held up for you.
Later Mark.
Just be aware ... part of rebuilding them is magnaflux checking them for cracks. Usually one or more are cracked somewhere which they won't rebuild so, you may get back 13 or so; not a whole set.
» BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» Hydralic roller compared to solid roller
» hydraulic roller cam with solid roller lifters
» JT557 HERE NEED SOLID ROLLER LIFTERS FOR ROLLER CAM
