QFT carbs
QFT carbs
is any one familiar with the QFT 950 A carb. What i need to know is, does it use the same throttle plate to main body gasket that a holly does? mine was being sucked in in one corner
Larry Williams- Posts : 884
Re: QFT carbs
Why don't you just lay one over the other and see if the holes line up or are the same.
Ace
Ace
powerstrokeace- Posts : 1496
Re: QFT carbs
i don't have a holly one with out disassembling another carb. If I remember right, the holly one was thicker than what I took out
Re: QFT carbs
Larry I am not sure but i will find out for you Mon morning.
Oakley Motorsports- BBF VENDOR SPONSOR
Re: QFT carbs
thank you Phillip
Re: QFT carbs
Larry Williams wrote:is any one familiar with the QFT 950 A carb. What i need to know is, does it use the same throttle plate to main body gasket that a holly does? mine was being sucked in in one corner
There are several different gaskets which Holley uses for the throttle body to main body junction.
Around that size it will depend upon what throttle bore size the 950A is based upon; a 1 11/16" bore uses one type gasket and a 1 3/4" throttle bore size uses a different one.
Re: QFT carbs
so the QFT carb does use a holly gasket of the proper size?
Re: QFT carbs
Larry Williams wrote:so the QFT carb does use a holly gasket of the proper size?
YES ... it can.
Re: QFT carbs
thanks a lot that helps
» BG Carbs...
» Parts selection for blown application (Budget - Mild Boost)
» Question: Blue Thunder 2x4 intake
» SV 1 Carbs
» Single venturi Pro systems carb.
» SV 1 Carbs
