1 piece oil pan gasket?
Guy's I'm buttoning up the motor and was getting ready to install the pan and was wondering if I should use any silicon gasket sealer on this. this is the first time using tis kind of gasket. The last thing I need is any kind of leak.
Ace
Ace
powerstrokeace- Posts : 1496
Re: 1 piece oil pan gasket?
on the corners and such, a small dab where the timing cover meets the block.
Thats it? OK off to the garage...........
Ace
Ace
thats it..... get it done !!! So easy a HeRo could do it !!
just make sure the pan rails are good and flat, and that the pan at the front and rear compresses the gasket down a bit...............you'll be golden.
» One piece oil pan gasket
» Which FelPro one piece oil pan gasket
» Oil pan studs for old covers & one piece gasket
» Installing 1 piece oil pan gasket - quesdtions?
» 2 piece plenum
» 2 piece plenum
