Installing 1 piece oil pan gasket - quesdtions?
Installing 1 piece oil pan gasket - quesdtions? Empty Installing 1 piece oil pan gasket - quesdtions?
Post  75truck July 30th 2017, 10:37 pm
Installing a M-6710-a460 1 piece Ford Racing pan gasket.
It has the steel reinforced gasket with grommets.
Do I use any sealant when installing?
Are these reusable?
Thanx
Bob
Tucson
75truck
Installing 1 piece oil pan gasket - quesdtions? Empty Re: Installing 1 piece oil pan gasket - quesdtions?
Post  rmcomprandy July 31st 2017, 1:05 am
75truck wrote:Installing a M-6710-a460 1 piece Ford Racing pan gasket.
Are these reusable?
Thanx
Bob
Tucson
A dab of silicone in the four corners is all. You can reuse them if you don't tear them.
That gasket has 1/4" grommets in the four corners and blocks before fuel injection have 5/16" bolt holes in the four corner locations.
Oh yea, I should mention, that the oil pan itself has a lot to do with whether or not you will experience a leak.
The oil pan rails MUST be flat ... if those rails are embossed, use a regular 4 piece gasket set because otherwise that junction WILL leak.
Post  IDT-572 August 6th 2017, 11:39 pm
Milodon, makes one that has the 5/16th bolt holes front and rear.
Installing 1 piece oil pan gasket - quesdtions? Empty Step drill worked great
Post  75truck September 8th 2017, 12:41 am
Step drill worked great.
https://2img.net/h/s25.postimg.cc/5ahzy675b/IMG_1468.jpg
My friend at Eddie's Marine told me that the step drill is less aggressive
than a regular drill.
Bob
Tucson
75truck
