Bob weight tolerance
Is there a bob weight tolerance for an external crank?
tconnection- Posts : 866
Re: Bob weight tolerance
Bobweight is determined by a measuring the weight of the parts and using a formula. What you have to watch is the weight difference cylinder to cylinder. Seen some factory stuff off 10 - 20 grams and be just fine. Most shops try to match everything within 2 grams.
Steve
Steve
466cj- Posts : 391
I've read several posts and articles of balancing an engine's rotating assembly and it's related parts. I have never understood why a so-called "balance job" is allowed to be OK! Is it balanced or not? Here at the shop we balance all components of the rotating assembly except the crankshaft, harmonic balancer and flywheel. Those items are "outsourced" with very specific instructions. We (my shop) are by no means perfect, but I think a "balance job' should be balanced not "good enough"!
Just more of my B.S.,
Dave.
Dave.
LivermoreDave- Posts : 972
LivermoreDave wrote:I've read several posts and articles of balancing an engine's rotating assembly and it's related parts. I have never understood why a so-called "balance job" is allowed to be OK! Is it balanced or not? Here at the shop we balance all components of the rotating assembly except the crankshaft, harmonic balancer and flywheel. Those items are "outsourced" with very specific instructions. We (my shop) are by no means perfect, but I think a "balance job' should be balanced not "good enough"!
Dave.
Larry Williams- Posts : 884
Depending upon the specific job, balancing can be correct with anywhere between 47% to 54% reciprocating weight when figuring the final bob weight.
What is most important is that the front and back be identicle.
The factory crankshaft is balanced to a vast allowable tolerance; about an once and a half, (around 40 grams).
» 429 rod weight
» maybe on here alrady but wondering max bore on an a460 block?
» 1970 outlaw mustang 25.1E good till 2015
» 557 vs 514 weight?
» Oil Weight ?'s
» Oil Weight ?'s
