cam bearings
cam bearings Empty cam bearings
Post  strokedmyford September 21st 2009, 8:19 pm
When is it time to go with a roller cam bearing? The bearings failed in one of our mud race engines (548 BBF)after about 6 races. Were running .760 net lift with 250-275 seat & 700 open on the springs with over .100 before coil bind. They are a king brand cam bearing. Maybe just not a good enough bearing? The rear bearing looked brand new the front was showing bad wear and the middle three were in the oil pan. We run three other BBF with similar setups with actually bigger cams going on three seasons now with out any issues.
strokedmyford
strokedmyford
cam bearings Empty Re: cam bearings
Post  Lem Evans September 21st 2009, 8:27 pm
I've used the King rod and main bearings but not their cams bearings . The Durabond performance cam bearings have done so well Ive never used anything but them ...I've not seen any issues with the 800# open springs we normally use . Did the cam feel good and free at the install ?
Post  strokedmyford September 21st 2009, 9:08 pm
Cam spun free at install.
strokedmyford
strokedmyford
Post  bbf-falcon September 21st 2009, 10:27 pm
Lem Evans wrote:I've used the King rod and main bearings but not their cams bearings . The Durabond performance cam bearings have done so well Ive never used anything but them ...I've not seen any issues with the 800# open springs we normally use . Did the cam feel good and free at the install ?
Lem, Do you think the xtra wide Cam bearings that are on the market are that helpful. I have always used the perf. Durabond w/o any problems also.
Post  Lem Evans September 22nd 2009, 10:22 am
Wider is better but the extra clearance they have is what i like the most .
