Cam Bearing Installation Question
Hi Guys,
I'm installing cam bearings for the first time. I know I need to line the oil passage holes up. Here's my question. There is 1/4 oil groove with a hole on each end. Does it matter which hole you use on the bearing? Just wondering...
Thanks!
Thanks!
dcon- Posts : 19
Re: Cam Bearing Installation Question
dcon wrote:Hi Guys,
Thanks!
If looking directly toward the front of the engine, the groove should be at 4 to 6 o'clock. Which direction the bearing gets installed does not matter as long as ONE oil hole lines-up on 2 thru 5; both should line-up on number 1.
» where the best place to get cam bearing installation kit
» Cam bearing question
» newbie bearing question
» Main Bearing Question
» Bearing Wear Question
