where the best place to get cam bearing installation kit
bigjohn2007
where the best place to get cam bearing installation kit Empty where the best place to get cam bearing installation kit
Post  bigjohn2007 March 20th 2011, 1:37 am
just looking to get some info about a tool to install my bearings.
bigjohn2007
bigjohn2007
where the best place to get cam bearing installation kit Empty Re: where the best place to get cam bearing installation kit
Post  schmitty March 20th 2011, 9:46 am
Any good name brand kit will be ok. I used a Snap On deal to put mine in. Just make sure it has a guide to center the shaft so you put the bearings in straight. Cool
Post  jbozzelle March 20th 2011, 11:59 am
I have a Lisle kit. Worked good for me a few months ago when I started putting mine together. It was my first time doing it and it came out fine. One thing to watch is making sure that the bearings actually ride on the cam journals. I had to move a few after I thought they were in the right spot...
Post  bigjohn2007 March 20th 2011, 1:41 pm
jbozzelle wrote:I have a Lisle kit. Worked good for me a few months ago when I started putting mine together. It was my first time doing it and it came out fine. One thing to watch is making sure that the bearings actually ride on the cam journals. I had to move a few after I thought they were in the right spot...
they have web site and what the cost?thanks
bigjohn2007
bigjohn2007
Post  95lightiningguy March 20th 2011, 3:47 pm
This is the one we pass around when needed. http://www.summitracing.com/parts/PRO-66820/
95lightiningguy
95lightiningguy
Post  Curt March 20th 2011, 3:51 pm
I had one made at the machine shop that pulled the bearing through, instead of beating it in. rabbit
Post  jbozzelle March 20th 2011, 5:05 pm
You just have to be different don't ya!!!
Post  Curt March 20th 2011, 9:20 pm
Well, not really. But I use it to install roller cam bearings, and you are in big trouble if you beat them in. Works great on standard bearings as well. Wink
Post  69F100 March 22nd 2011, 5:35 pm
95lightiningguy wrote:This is the one we pass around when needed. http://www.summitracing.com/parts/PRO-66820/
X2 That the same kind I have just watch the rubber o-rings if one get some missing peaces change it or you take a chance of messing the bearing up.If you going to store it for a while grease the o-rings up good to keep the o-rings from dying out.
Jim
Post  bigjohn2007 March 27th 2011, 4:09 pm
Got one like that guys it worked like champ Cool
bigjohn2007
bigjohn2007
Post  BIGDOG466 March 27th 2011, 4:53 pm
Goodson sells them also,
I made one to pull them in works allot better.
BIGDOG466
BIGDOG466
