Cambearing Installation
Cambearing Installation Empty Cambearing Installation
Post  Gregdacrack September 27th 2019, 10:38 am
I noticed that only the first Bearingplace on the Front has two oilholes. And the four behind have just one Oilhole. So why do all Bearings have 2? My old Ones like my New Ones aswell. Plus all five King bearings are the same Type and looks like they have none special Position.
Cambearing Installation 20190916
Cambearing Installation 20190914
Cambearing Installation 20190915
Gregdacrack
Cambearing Installation Empty Re: Cambearing Installation
Post  Gregdacrack September 27th 2019, 10:40 am
Cambearing Installation 20190917
Gregdacrack
Post  Gregdacrack September 27th 2019, 10:45 am
So do i need to make sure to Hit just one of the Bearingholes at the four Places behind the Front or is there something i need to know?
Gregdacrack
Post  away September 27th 2019, 10:57 am
Nothing special here. The second pic you have loaded the hole on the outermost portion will be slightly exposed when you get the hole in the center of the bearing to line up. It just needs a portion of it uncovered to help oil the timing chain sprocket. Why these cam bearings have two holes I have no idea (manufacturing process related maybe?) But I always think about how the engine rotates and clock them in a way to where as if the bearing was to slip for any reason and turn is has an opportunity to line back up with the other hole and free itself if that makes sense.
away
away
Post  gt350hr September 27th 2019, 11:20 am
All five cam bearing bores in the block are the same size unlike other Ford engines. Bearing manufacturers simply supply five of the same bearing because of that . As you noted it's only important on the front position as lond as one hole is lined up on the other four , you are good to go.
gt350hr
