newbie bearing question
Ok I did some measuring on the mains and rods tonight and on the mains the measurements are as follows
Block crank
#1 3.190 2.9995
#2 3.1905 2.9990
#3 3.1905 2.9990
#4 3.190 2.9995
#5 3.1915 3.000
Should I have the mains align honed? and what bearing size and type should I get?
Con rods 2.3245 and rod journals on crank 2.2 chromed
Con rod bearing recommendation please?
Block crank
#1 3.190 2.9995
#2 3.1905 2.9990
#3 3.1905 2.9990
#4 3.190 2.9995
#5 3.1915 3.000
Re: newbie bearing question
I suspect you'll have to hone the main housings to 3.193"....the high side.
The crank is toward the 'fat' side..... I suspect a half or full set of extra clearence bearings will be needed.
Thanks Lem, I checked these with a 4 place dial caliper last night. Going to double check the numbers with a set of mic's. tonight.
Also what brand/type of bearing do you recommend? coated not coated?
The coated stuffs the cats ass if you have the $$$ for it IMO.
HorsinAround wrote:Thanks Lem, I checked these with a 4 place dial caliper last night. Going to double check the numbers with a set of mic's. tonight.
You'll need a dial bore gauge to check the housing bores correctly. I use ACL mostly for the rods. King, ACL, F-M, all seem to do a good job.
Outstanding. someone loaned me some mains std size, so I am going to install them tonight and check clearances. I'll call you tomorrow with an order.
I love X bearings,seems like everything I assemble anymore needs them. BFEvansraceparts is the go to place for race parts.
bbf-falcon wrote:I love X bearings,seems like everything I assemble anymore needs them. BFEvansraceparts is the go to place for race parts.
My wife has blocked Lems number on my phones along with Summit and jegs lol
» Cam bearing question
» Newbie question on manifolds
» Cam Bearing Installation Question
» Bearing Wear Question
» Bearing check question
