Best cam bearings
+11
norm
CDMBill
hienergy557
powerstrokeace
jeffgfg
garys gt
15 posters
Best cam bearings Empty Best cam bearings
Post  garys gt February 22nd 2014, 4:09 pm
What kind of cam bearings would be the best for a 557 with scj aluminum heads and a solid lift flat tappet cam. I have not bought the cam yet. I have read about the wide cam bearings and coated bearings. At what point are the wide bearings needed and when are the coated bearings needed.
garys gt
Best cam bearings Empty Re: Best cam bearings
Post  bbf-falcon February 22nd 2014, 4:57 pm
The wide bearings are a nice feature to have especially on a big roller w/heavy seat pressure,but w/flat tappet not that big of deal imo.
Post  garys gt February 22nd 2014, 6:14 pm
What about coated.  Does it make a difference on a application like mine.
garys gt
Post  69F100 February 22nd 2014, 8:43 pm
I have ran both and both worked great the plain non coated looked just as good as the coated bearing did when I replaced them I replace mine when I freshen the engine up from what I have understood the coated bearing is supposed help on cold start up and last longer.
Post  richter69 February 22nd 2014, 8:46 pm
I like the "wide" bearings in all my bbfs
Post  garys gt February 22nd 2014, 10:17 pm
Who has the best price on the wide cam.bearings.
garys gt
Post  jeffgfg February 23rd 2014, 12:31 pm
Lem
jeffgfg
Post  richter69 February 23rd 2014, 12:33 pm
BF Evans Raceparts......
Post  rmcomprandy February 23rd 2014, 1:02 pm
richter69 wrote:BF Evans Raceparts......
REALLY ...?
Post  richter69 February 23rd 2014, 2:34 pm
four sure....
Post  garys gt February 23rd 2014, 3:24 pm
about what do the wide bearings cost. I have seen the regular width bearing for sale and seen prices. I have not seen the wide bearing for sale. I read they were 5 number 1 bearings 351 Cleveland size.
garys gt
Post  rmcomprandy February 23rd 2014, 8:04 pm
garys gt wrote: I read they were 5 number 1 bearings 351 Cleveland size.
They are.
Post  powerstrokeace February 23rd 2014, 8:38 pm
Lem keep them In stock and there roughly $50.
Ace
powerstrokeace
powerstrokeace
Post  hienergy557 February 23rd 2014, 9:15 pm
rmcomprandy can supply them as well.
I guess it'll depend who you are closest to. Lem or Randy.
hienergy557
hienergy557
Post  CDMBill February 24th 2014, 12:49 am
If your block is designed for them, roller cam bearings are better IMHO than conventional.
CDMBill
Post  garys gt February 24th 2014, 8:33 am
CDMBill wrote:If your block is designed for them, roller cam bearings are better IMHO than conventional.
my block is a factory block so roller bearings will not be a option. will pm both lem and randy and see if they will get back to me with info. going to need a cam at some point. thinking about going with a custom cut solid flat tappet. any ideas on what lift and durations might work well with my build. I was thinking 260s @ .050 and 650 lift range.
garys gt
Post  69F100 February 24th 2014, 1:15 pm
Both of them can design you a cam Randy designed mine in my 460 Lem designed the one in my buddy's 557.
Post  bbf-falcon February 24th 2014, 1:43 pm
Explain why Exclamation
Post  richter69 February 24th 2014, 2:24 pm
gonna call bullshit on that one......
Post  rmcomprandy February 24th 2014, 3:13 pm
IF you are NOT using a hardened steel camshaft then, you CAN'T use them without destroying parts.
Post  Lem Evans February 24th 2014, 3:46 pm
Yep, gotta be a good steel cam for the roller bearings.
Post  norm February 24th 2014, 7:52 pm
I could see applications where roller bearings are necessary. but better than babbit? not necessarily.
norm
norm
Post  cool40 February 24th 2014, 8:45 pm
I wouldn't want one over the other and sure wouldn't machine a block to use rollers. I have both without problems from either. .....
Post  dfree383 February 24th 2014, 10:56 pm
Not for a street application and cast cam core.
Post  MBBFord February 26th 2014, 12:08 am
So in a mild 460 would stock replacement bearings f30 be good enough for about $20?
Or durabond fp30 bearings for $30
The durabond fp30T are the coated bearings for $60
MBBFord
