A460 HEAD PORTING
powerstrokeace
tconnection
A460 HEAD PORTING Empty A460 HEAD PORTING
Post  tconnection March 14th 2012, 10:36 pm
Is there any key points to focus on when polishing out the ports and bowls in the tfs ahead? I mean besides the rough casting, the sharp edges and the short turns? If it's all secrete, that's fine, I understand.
tconnection
A460 HEAD PORTING Empty Re: A460 HEAD PORTING
Post  powerstrokeace March 14th 2012, 10:40 pm
Send them to Charlie
ACE
powerstrokeace
powerstrokeace
Post  cool40 March 14th 2012, 10:45 pm
the short turn is where i gained a lot on my old A460's,not sure on the tfs heads but they're good out of the box compared to mine.
Post  tconnection March 14th 2012, 10:55 pm
IIIIIIIII don't know. i might mess around and get that 1,000 horse i'ld like to have if i send them to him. Which ofcourse since i bought them from Lem i should be able to get in line. Uma have to check the cost. This ahead setup can be high dollar, is high dollar. But! It is what it is.
tconnection
Post  cool40 March 14th 2012, 11:00 pm
pay to play............. Smile
Post  IDT-572 March 14th 2012, 11:05 pm
cool40 wrote:the short turn is where i gained a lot on my old A460's,not sure on the tfs heads but they're good out of the box compared to mine.
The old A heads short turn looks like a 90 * turn straight down. Work out the short turn and the bowl and you could look like a hero............ Wink
Post  powerstrokeace March 14th 2012, 11:26 pm
Charlie porting is priced right. Hand porting or CNC porting. But don't waste time just have him do them. I know that nows not the time because you wont get them back till FALL! affraid
Ace
powerstrokeace
powerstrokeace
Post  cool40 March 14th 2012, 11:28 pm
geek
Post  tconnection May 2nd 2012, 12:41 pm
Im basically done working on these heads. I got the exhaust polished pretty slick. How slick should the intake be? I got some pics but i gotta get them on photo bucket and figure out how to post. Its been awhile since i post some pics.
tconnection
Post  IDT-572 May 2nd 2012, 12:43 pm
You don't want the intake port polished just the finish a sanding roll leaves is fine.
Post  tconnection May 2nd 2012, 1:04 pm
They are just as slick as the exhaust. What problem can being to slick cause?
Can any part of the port remain slick?
Thanks for your info.
tconnection
Post  IDT-572 May 2nd 2012, 1:06 pm
A slick surface could tend to have fuel adhere to it and dribble into the port. A semi ruff surface wont let it do that. Not the end of the world just not optimum.
Post  tconnection May 2nd 2012, 1:11 pm
I understand, thanks alot.
Thanks again
tconnection
Post  Barney May 2nd 2012, 1:42 pm
tconnection wrote:They are just as slick as the exhaust. What problem can being to slick cause?
Just rough em back up a little. As has been said, the short turn and bowl will give you the greatest return.
Barney
Barney
Post  tconnection May 2nd 2012, 1:51 pm
120 grit roll should do it?
tconnection
Post  IDT-572 May 2nd 2012, 2:33 pm
Sure, that's fine.
Most flow gains (most cfm in the least amount of grinding time) are within .750 of the seat on a BBF head. Wink
Post  rmcomprandy May 3rd 2012, 12:29 am
They WILL flow more air when they are slick however, being a rough surface but, smooth contour WILL make more power with less fuel.
Post  tconnection May 3rd 2012, 12:40 am
Ok thanks, sound good. Im gonna go back over them with a 120 grit roll.
what about the intake manifold? does it need to be a lil rough also?
tconnection
Post  dfree383 May 3rd 2012, 1:14 am
tconnection wrote:Ok thanks, sound good. Im gonna go back over them with a 120 grit roll.
Yes.
Post  rmcomprandy May 3rd 2012, 9:59 am
Personally, I use 80 grit on the intake ports.
