Scj head porting
Scj head porting Empty Scj head porting
Post  fordmonsta December 20th 2016, 7:18 pm
I'm fixing to pull my 552 out of the fairlane and throw some flat tops in it while it's apart I wanna do some port work on the heads they are the Frpp scj heads is there any one part that I should focus on such as short turn on the intake or exhaust I'm also going to do the back cuts on the valves
fordmonsta
Scj head porting Empty Re: Scj head porting
Post  rmcomprandy December 20th 2016, 8:59 pm
fordmonsta wrote:I'm fixing to pull my 552 out of the fairlane and throw some flat tops in it while it's apart I wanna do some port work on the heads they are the Frpp scj heads is there any one part that I should focus on such as short turn on the intake or exhaust I'm also going to do the back cuts on the valves
Well,  when you machine the places which add most of the airflow you will tend to find water.
To be pretty safe ... Remove most of the pushrod bump in the intake runners, machine the wall away behind the pushrod bump into the bowl as mush as you dare and pull back and lower slightly the short side radius near the exhaust port then round the entire short turn
Don't lower the exhaust short turn other than to round it. Pull back the wall behind the head bolt hole.
Anything else and you will probably need a welder.
Post  fordmonsta December 20th 2016, 9:04 pm
Thanks for the info
fordmonsta
