D0VE head porting Q
D0VE head porting Q
I'm porting my D0VE heads as per Scotty's website, and there is one thing i'm not sure about. IF a CJ style intake, or Victor is NOT being used, is it still beneficial to do a the Victor port match? These heads are going on a nothing special 30 over flat top 460 for now.
Diggindeeper- Posts : 800
Re: D0VE head porting Q
The short answer is NO...
Although the heads might flow better on a bench when you put on the intake you will be disappointed.
Std gasket match 1 inch in and widen port at push rod pinch to 1.800"
Thank you very much.
I did not want to do more than i had to
» Scj head porting
» Short turn radius tip to stabilize dove heads with 2.25 valve at high lifts.
» head porting
» A460 HEAD PORTING
» D3VE head porting ?
» head porting
» A460 HEAD PORTING
