head porting
Bret Powell
onemadton
head porting
hey guys im new to this site and was wanting your input i have a set of 429 cj heads that are stock and was wanting to get them ported who do you recommend thanks
onemadton- Posts : 2
Re: head porting
give Phillip a call @ Oakley Motorsports 270-929-5185 and he can get you handled
Re: head porting
bruno wrote:give Phillip a call @ Oakley Motorsports 270-929-5185 and he can get you handled
'Cause he sponsors this forum!
Bret
Bret Powell- Posts : 133
Re: head porting
What will the heads be going on? If not a pulling iron headed class truck,you would be better off money/HP wise to buy a set of stock Alum. heads for the money. You will end up having more money in the iron heads.jmo
Re: head porting
Bret Powell wrote:bruno wrote:give Phillip a call @ Oakley Motorsports 270-929-5185 and he can get you handled
Bret
yes and he has several of the top names including himself that does port work for his engine programs
Re: head porting
onemadton wrote:hey guys im new to this site and was wanting your input i have a set of 429 cj heads that are stock and was wanting to get them ported who do you recommend thanks
As Rick has mentioned and I must say, a set of unmolested factory 429 CJ heads have value!
Dave.
LivermoreDave- Posts : 972
Re: head porting
The heads are the iron cobra jets. He has to run iron heads to meet the class rules (truck pulling)& is a good friend of mine. I know you guys will steer him straight. IMO Phillip & Bret are more than up to the task as well as some others on the site, like Charlie & Randy. Any of these guys will treat ya right! Good Luck & let me know if I can help.-A
4speed- Posts : 127
Re: head porting
If these are for a truck pulling engine, be careful not to look for absolute max flow numbers at the cost of port velocity.
A "sewer port" can flow a lot of air but, comes-up quite a bit shy of power.
Re: head porting
It is very unfortunate in the street/stock truck pulling classes that a set of production iron heads no matter what brand of truck is like taking a switch to a gun fight. Bret Powell does very well w/cj'sbut the ones in my neck of the woods are in the back of the field. The EX514 iron heads for the BBF is the head in demand for the top runners around here. Good luck and have fun because in the end ,that's what it's all about.
Re: head porting
The class he is running in only allows stock production iron heads. The heads have to come from a car or truck that came down the assembly line.-A
4speed- Posts : 127
Re: head porting
That's good,that gives the little guy a chance to be competitive. Rules sometimes forget the beginners.
Larry Williams- Posts : 884
Re: head porting
thanks guys for all your input im new to this forum and i new you guys would put me in the right direction
» Short turn radius tip to stabilize dove heads with 2.25 valve at high lifts.
» Scj head porting
» D3VE head porting ?
» D0VE head porting Q
» A460 HEAD PORTING
» Scj head porting
» A460 HEAD PORTING
