gear fluid ?
+6
Barney
yellowhorse7
10 posters
gear fluid ?
how many passes before you change the rear end gear fluid ? and what do you guys use ?
Re: gear fluid ?
I use 75-140 I get from work, its a syn lube........good chit and its free.
I change gears pretty often so its changed pretty often, always looks new.................its the same lube used in all the truck diffs at work, honestly they see more load than the car does.................and heat.
Re: gear fluid ?
Gears only last a few years for us and we change the fluid then, so I would say.....every couple of years. LOL!
Oh and we use 75w-90 full synthetic.
whatbumper- Posts : 3024
Re: gear fluid ?
bruno wrote:how many passes before you change the rear end gear fluid ? and what do you guys use ?
Every season. Usually 30 passes or so
yellowhorse7- Posts : 1382
Re: gear fluid ?
i bought the car 6 years ago ............. i guess its time to get some gear fluid
Re: gear fluid ?
age wont hurt it,lol. how many passes,5-6...........bruno wrote:i bought the car 6 years ago ............. i guess its time to get some gear fluid
Re: gear fluid ?
cool40 wrote:age wont hurt it,lol. how many passes,5-6...........bruno wrote:i bought the car 6 years ago ............. i guess its time to get some gear fluid
damn Lee , go to bed ...your making my insides hurt
Re: gear fluid ?
damn! yall spend money on shit for no reason!Barney wrote:I change it at 40 passes.
Re: gear fluid ?
Damn, I'd have been changing it 7 or 8 times a year when I raced every weekend. I usually run it till the gear breaks!
I usually change engine oil at 35-40 passes.
BigDave65- Posts : 567
Re: gear fluid ?
Peace of mind I guess. If I can't afford gear lube then I'm selling out.cool40 wrote:damn! yall spend money on shit for no reason!Barney wrote:I change it at 40 passes.
Gear oil
I have been using richmond brand gear lube .It is what they recomend whenever you use one of there gear sets .It is a synthetic .I had this in my car a couple of years .When I pulled my gear out (4.56 richmond) this year it looked great .I have also used the mobil 1 syn.gear lube with good luck.Doug
manofmerc- BBF CONTRIBUTOR
Re: gear fluid ?
Red Line.
res0rli9- BBF CONTRIBUTOR
gear oil
Red line High Shock 75-90wt. Synthetic, and micro shock particles cushion ring & pinion. I use it in my toploaders as well, great stuff. I only change it when I change ratios, maybe once a year.
blown473- Posts : 376
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» C6 fluid help please
» Pro Stock Trans gear ratio / Rear Gear
» 460 rotor gear connecting gear bad
