here is a loaded question... What spark plugs should i use???
yellowhorse7
Barney
racinghabbit
mud race engine.. 545, iron headed, c9ve. fully ported , full roller , msd ignition. 14.1 :1 compression.. dual plane intake with 1050 dominator...
just wondering what you would suggest for spark plugs..
thanks
thanks
racinghabbit- Posts : 575
Re: here is a loaded question... What spark plugs should i use???
I've used all 3 the AR33 is perfectly good too. The 45 and 124 are 1/2 the cost and I've found last a little longer. Just my experience, not disagreeing.
Barney wrote:I've used all 3 the AR33 is perfectly good too. The 45 and 124 are 1/2 the cost and I've found last a little longer. Just my experience, not disagreeing.
Buy the adapters and run a AR3932
yellowhorse7- Posts : 1382
The adapters like Garrett machine offers are an option, but are not needed unless one needs a plug colder than the AR32. Unless Racinghabbit gets rid of the dual plane intake manifold and puts the hose to it i'd doubt his engine wants an AR3932 sparkplug.
he could put some m5 in it and go with ngk9's!
For some reason, it's difficult to find the AR33's around me, so I went with the Garret machine adapters and run the NGK's. Not that they are any better, just easier for me to get local. I like the NGK BR9es on the frosty jug
kjett- Posts : 1169
Lem Evans wrote:The adapters like Garrett machine offers are an option, but are not needed unless one needs a plug colder than the AR32. Unless Racinghabbit gets rid of the dual plane intake manifold and puts the hose to it i'd doubt his engine wants an AR3932 sparkplug.
Good point. I assumed that he was spraying it
Motorcraft BTF-1 Best racing 18mm plug.
k.pascoe- Posts : 30
not spraying it... ar33 are made by who?
never mind its an autolite racing plug
what kind of plug gap do you guys run??
thanks
thanks
Gap?
I have ar33 .. got them from carquest .. got me 16 overnite!!
I would guess between .030 and .035
lghting94- Posts : 762
Biggest gap you can without putting out the spark. With your deal I'd start at .040
I run NGK's at .044
crittersf1- Posts : 521
I called autolite and talked to there racing tech. He told me Not to gap ar32 or ar33 spark plugs. and he also told me to run ar32 's with my engine build..
Just passing it on .
ar33 factory gap is .030
p.s. i did gap a set of ar33 to .040 and i am having problems with them fouling out.. Just an fyi...
» heads with raised exhaust port question? also what spark plugs to run?
» Loaded question??
» spark plugs
» P 51 spark plugs
» E3 Spark Plugs
» Loaded question??
» spark plugs
» P 51 spark plugs
» E3 Spark Plugs
