Removing brake booster
After removing brake booster what do you use for the rod. I removed the one from the booster but won't be long enough.
digger460- Posts : 84
Re: Removing brake booster
You can get a master cylinder for a truck with manual brakes or just fabricate a rod. I used one from an 80s Ranger with manual brakes.
fordpullin- Posts : 23
What I did
Digger
I bought a reman master for an older ford with manual brakes and it came with a longer rod. Just had to redrill the hole in the pedal.
Kirk
Kirk
tenforty_2- Posts : 42
» Fox body swap, need a smaller brake booster- what year booster?
» brake booster
» 5.0 foxbody brake booster
» power brake booster
» Brake Cylinder/Booster
» brake booster
