power brake booster
norm
ThndrChkn
Old blue Racin Team
dirt_worker
Godzilla
power brake booster Empty power brake booster
Post  Godzilla August 26th 2012, 7:50 am
I have a 67 Ford drag truck, with a big block and c-6. It has a 9in. booster on it now, and i need more clearance between it and the valve cover. Does anyone know of a smaller booster that will bolt up to the factory bracket. Any help would be greatly appreciated.
Bob
Godzilla
power brake booster Empty Re: power brake booster
Post  dirt_worker August 26th 2012, 8:25 am
why don't you just remove the booster all together?
My 67 f100 has never had pb and has stopped fine from 127mph runs....
dirt_worker
dirt_worker
Post  Old blue Racin Team August 26th 2012, 9:11 am
i took the pb off my 77 and it stops better than it did with it,,,, granted im in the mud but im on 38s
Old blue Racin Team
Old blue Racin Team
Post  ThndrChkn August 26th 2012, 9:56 am
Agreed. Unless you feel you absolutely have to have it, I'd just ditch it altogether. That was one of the first things I took off of my '86, and it stops pretty well from just less than 140 mph on a 1/4 mile run. It DOES need rear discs though... Very Happy
ThndrChkn
ThndrChkn
Post  norm August 26th 2012, 3:05 pm
Did you guys JUST put a manual Mc on or did you do something to the proportioning valve as well?
norm
norm
Post  dirt_worker August 26th 2012, 3:34 pm
the bore size of the mc has a lot to do w overall brake pressure and pedal feel.
Mine never had pb so I cant say w certainty how effective just taking the booster off would be but Id assume the pedal would prob be quite firm. Id just get a reman master from a non pb f100 w a smaller bore size. ( most likely 1") and go racing.
Does your truck already have disk brakes on the front?
dirt_worker
dirt_worker
Post  Old blue Racin Team August 26th 2012, 6:30 pm
all i did was un bolt my MC from the booster then i un bolted the booster from the firewall, then bolted the mc back to the firewall using i believe the bottom bolt holes for the booster and cut down the brake rod untill it was just enough to let off the mc but not enough to fall out of it
Old blue Racin Team
Old blue Racin Team
power brake booster Empty power break booster
Post  Godzilla August 27th 2012, 3:49 am
I would like to keep a booster. Does anyone know if there is one off a mustang that would work? what about a aftermarket one?
Bob
Godzilla
Post  jasonf August 27th 2012, 9:45 am
I guess you are going to have to take some measurements and hit the auto wreckers. Have you tried the FTE forum? I am sure someone there would know.
http://www.ford-trucks.com/
Post  bigblok2000ranger August 27th 2012, 10:17 am
I think 9 inch is about as small as your gonna get, hydroboost is another option.
bigblok2000ranger
bigblok2000ranger
Post  ThndrChkn August 27th 2012, 10:31 am
norm wrote:Did you guys JUST put a manual Mc on or did you do something to the proportioning valve as well?
I never had to do anything with the proportioning valve for my truck.. The only thing I had to do was I bought a manual master from the parts store, and change the length of the pushrod to get the right stroke on the pedal. If all you're doing is drag racing, there really is no need to want or keep the booster...
ThndrChkn
ThndrChkn
Post  jasonf August 27th 2012, 11:21 am
If you end up going with a small street rod style booster make sure you get a dual diaphragm unit. The singles do not offer much help at all.
Post  samiam August 28th 2012, 1:22 pm
Godzilla wrote:I would like to keep a booster. Does anyone know if there is one off a mustang that would work? what about a aftermarket one?
Bob
I too ,wanted to keep the booster, and this is what I ended up with......
power brake booster IMG_1877
samiam
samiam
Post  Old blue Racin Team August 28th 2012, 6:12 pm
That dont look any smaller than the one that i took off my 77 F-150,,,,
Old blue Racin Team
Old blue Racin Team
Post  69F100 August 29th 2012, 3:04 pm
When I installed the disc brakes on the front of my 69 f100 I used everything off a 74 f100 and left the booster off and put the manual master on I was running a 351c and did not have much vacume so I left it off like has been said it stops fine.But if you going the put a p/b on iy look for a f150 that came with the 460 in it and see what they have on them but I am sure they was 9'' to.
